Model 42-380 veneer
I am finishing the cabinet on a 42-380 and the instrument panel was carved up by an experimenter so I repaired it but now need to get a piece of veneer to re-cover it.
Does anyone know what type of wood veneer was used originally. It looks like it might be mahogany.
Also I just got a model 70 cathedral which when it was shipped to me the speaker tore loose and broke up the speaker grille wood pretty badly. I think I found all the bits but would it be practical to try to repair it or does anyone make a replacement?
Steve D
From my Resource Links Page:
Dick Oliver's Reproduction Philco cabinet parts.
For cathedral models:
Front Panels
Base Moulding
Rear Arch Supports
For the Philco Grandfather or Colonial clock:
Finials
Trim pieces
Call or write for your needs.
Antique Radio Service
Dick Oliver
1725 Juniper Place, #310
Goshen, IN 46526
Ph. (574) 537-3747
Email: dolivears AT aol DOT com
Probably walnut veneer on your 42-380. Not the figured, fancy tiger or "butt" walnut, just a plain pattern. It will match the grain pattern on the top left and right panels, and run from front to back - vertically where it bends over to cover the front where the hole for the dial and knob shaft holes are.
I'll ditto Chuck's recommendation of Dick Oliver to make a replacement panel for your 70. He does fantastic work. He's listed on the PhilcoRadio.com Resources page also. By the way, he also does refinishing, cabinet repair, and even makes complete reproduction cabinets for the 20, 70 and 90 cathedrals.
Hi Steve,
I just ordered some parts from Dick last month. A very nice man. The price list he sent me has a front panel for a 70 listed at $50.00 and $5.00 shipping. Just so you will know what to expect.
Hope this helps
Thanks a lot for the help, guys. I will contact Dick Oliver and start to search for walnut veneer on the net.
Thanks again
Steve D
schematics
thanks I'll try the polar caps seperatelymseno — 07:38 AM
Hi SQ55, A strange issue indeed!  Just so I have you straight, on a dim bulb you get normal operation after the set warm...MrFixr55 — 12:44 AM
schematics
I think mseno is talking about cap# 27 which is a multisection but in a paper tube. In cases like that I've usually be ...klondike98 — 11:25 PM
schematics
Ohrenet  :roll: For their price I would chase a fly in a field.  :twisted:Vlad95 — 11:21 PM
A bit more work on the Motorola. I got the repro battery together right up until I realized the snap clips on the top o...klondike98 — 10:45 PM
schematics
Often restuffed. If a twistlock, Hayseed Hamfest makes modern replacements. morzh — 09:18 PM
schematics
Looking for a multi-sectional 8+16 mfd cap. Can't find any suppliers that carry it.mseno — 08:45 PM
schematics
Richard, thanks so much, greatly appreciatedmseno — 08:39 PM
I'm starting to restore a Philco 16X, I need spare parts. Please, help me find ...
Peter; I believe that the "A" suffix means that it has as 25 cycle power transformer, not all Canadian sets...Arran — 07:05 PM
I am back tracking on my resistors as the one that burned based on the old one's resistance was correct but another resi...osanders0311 — 05:34 PM
There are currently 1084 online users. [Complete List]
» 2 Member(s) | 1082 Guest(s)
