F-1740 Filter Cap Voltages
I'm recapping a F-1740 that was mostly unmolested except that the 3 section filter cap was missing. The schematic shows a 20mf off the 7C5 output tube, and a 15 mf on the B+ and 10mf to the speaker coil. Unfortunately, the schematic doesn't give the voltages, only the mf values. (1940). I suspect the 15 and 10 are around 350 volts, don't know about the 20 mf. Can somebody give me a hand with what voltages correspond to which mf values? The original part no is 61-0089. Thanks
Here's a post on another forum regarding the caps:
<!-- m --><a class="postlink" href="http://www.antiqueradios.com/forums/viewtopic.php?f=19&t=180388&view=next">http://www.antiqueradios.com/forums/vie ... &view=next</a><!-- m -->
Carl
Northern Panhandle, WV
Excellent! old part nos come in handy, thank you
Hi and Welcome to the phourm!
You can't go wrong by putting a cap in there with a higher voltage rating. You could use 450v caps in place of the 350v jobs. The only issue may be size. You mention that there is a cap off of the 7C5. If it is connected to the cathode the voltage rating is going to be much lower as there isn't much voltage there. Something in the 35-50v range will be fine. Cathode will have about 10-15v on it.
ps When you replace #76 it needs to be a high voltage job at 1.5 or 1.6KV. If it goes bad it will take the power transformer and chopper (vibrator) with it.
What kind of meter is it? Relative to what is the voltage being measured? Are the AC line filter caps C53A/B hooked up...morzh — 10:47 AM
Hi, what I'm seeing on the schematic is one wire from the output transformer goes to B+ and the other goes to the 7B5 pl...RodB — 10:42 AM
schematics
The Philco Library is great for Philcos.  Great source of info. Philco Libraryslford310 — 09:59 AM
schematics
Hello MSENO, Welcome to the Philco forum and here is the schematic for that Philco! 41-290 Sincerely Richardradiorich — 09:48 AM
I double checked everything around the filter caps and it all seems to be hooked up right... Here are the voltage on ...sq65 — 09:45 AM
schematics
I'm looking for a readable schematic for a 41 290. can anyone help?mseno — 09:33 AM
Rogers Majestic R-646
Since the original schematic was in an old unreadable style, I created a new schematic diagram. Owners of this radio ca...Vlad95 — 11:09 PM
Hello Peter, What great project I am looking forward to see your progress with this console !! Sincerely Richardradiorich — 10:20 PM
Ok guys, JustRadios has me worried after reading an article about purchasing resistors and I hope that I haven't made a ...osanders0311 — 08:59 PM
Yeah, I have no idea what's going on there. I will re-check it in the morning, and also trace out the B+...sq65 — 07:55 PM
There are currently 1299 online users. [Complete List]
» 1 Member(s) | 1298 Guest(s)
