Finished 90 chassis
Hey everyone,
I just wanted to share some pictures of my just finished 90 chassis. I did a complete overhaul on it, along with recapping, I replaced all the resistors save the BC resistor with 1 watt flameproof units. After checking the old resistors I found that most of them were at least 20% over tolerance! I also replaced all the wiring, cleaned and painted the chassis and power transformer. It was a lot of work, but I really enjoyed doing it!
It worked on the first power up and it plays beautifully. All that is left is to align it.
Now, on to cabinet!
[Image: http://i1160.photobucket.com/albums/q500...ure015.jpg]
[Image: http://i1160.photobucket.com/albums/q500...col007.jpg]
[Image: http://i1160.photobucket.com/albums/q500...col006.jpg]
[Image: http://i1160.photobucket.com/albums/q500...col005.jpg]
[Image: http://i1160.photobucket.com/albums/q500...col004.jpg]
That looks really nice. I typically don't care for painted chassis but you and Ron seem to make them look good. Is the cabinet a console or cathedral?
Very nice job! Do you have a picture of the underside?
Very good! Icon_thumbup What kind of paint did you use, and what color?
Thanks! As a rule I prefer the original finish as well. However in this case, there were several areas of condiderable rust on the chassis. After removing the rust, the chassis looked blotchy and uneven. Seeing as this was THE cathedral I wanted for so long I wanted to the best job I could! So I decided to paint it. I used Krylon's satin nickel paint that I read Ron uses. It works very well and leaves finish that doesn't scream "I'm painted!!" .
The big part is the prep work, it took me an hour just to tape up everything!! I also sanded and then polished all the coil cans with Mother's metal polish. then several light coats of paint. I had to remove the tuning condensor anyway to replace the rubber mounts so that was diassembled and cleaned and buffed. Here are some before and after pics.
[Image: http://i1160.photobucket.com/albums/q500...ure024.jpg]
[Image: http://i1160.photobucket.com/albums/q500...col008.jpg]
[Image: http://i1160.photobucket.com/albums/q500...ure105.jpg]
[Image: http://i1160.photobucket.com/albums/q500...ure106.jpg]
[Image: http://i1160.photobucket.com/albums/q500...ure021.jpg]
[Image: http://i1160.photobucket.com/albums/q500...ure004.jpg]
Very Nice!!!
That is just an great job on that chassis. Always wanted to try something in that depth of restoration but haven't had the courage. Congrats on a really fine job.
Jerry
Hello Bob, What nice looking set it looks like a Emerson that I have you did great job with the two Electrolytic cans ....radiorich — 02:04 AM
New find. 91X code 225
Hello Paul, Well, done it looks great ! Sincerely Richardradiorich — 01:55 AM
Congratulations, Paul! That was quick...you made short order of that chassis restoration! And no coils to rewind...bonus...NostalgiaRadioTime — 01:07 AM
Bob; I was thinking the same with that 150 ohm resistor, put a larger value replacement in it's place to compensate f...Arran — 01:02 AM
And the chassis is all done, all caps and bad lamp wiring replaced, power switch repaired and in place, dial string tune...pdieten — 12:37 AM
As I think more about that 150 ohm resistor that directly follows the selenium diode, I’m going to have to add some seri...klondike98 — 11:47 PM
It looks like all the resistors except one are OK. Arran mentioned replacing the sand 150 ohm resistor and mine looks l...klondike98 — 02:25 PM
Yeah the 121/221 documentation was correct for the RF end of the radio. It left me scratching my head when I was looking...pdieten — 11:59 AM
philco predicta
Hi CGL, Yes, troubleshoot the 140V Power supply, something is definitely loading it down, and since this supply excl...MrFixr55 — 07:32 AM
1934 American Bosch 440T restore on YouTube
Looking forward to Part 2.Jimradio — 07:30 AM
There are currently 218 online users. [Complete List]
» 1 Member(s) | 217 Guest(s)
