philco model 44
this is my first post i am restoring a philco model 44 and it has parts removed could use picture of the chaissis in restored or untouched condition to help restore
Welcome! I have a recently acquired 44B, but it's been modified a bit...a 1/4" jack has been added in back of the chassis. If you think this will help anyway, I can try to get a picture made this weekend...
thanks i can use your picture all the paper capacitors are removed from the chaissis the filter capacitors are still there with no wires leading to them
Okay, here's the photo...I warned you, it was modified to add a phono jack - and not only that, electrolytic capacitors were tacked in years ago.
[Image: http://www.philcoradio.com/ebay/44chas_sm.jpg]
Here's a link to a higher-resolution version - please let me know when you get it, as I am not going to leave this up on the server:
http://www.philcoradio.com/ebay/44chas.jpg
I hope it helps in some way.
thanks i made a copy of it and stored it in my computer. it looks pretty good.
If you still need a good pic of a virgin 44 chassis, I just found mine. Email me at "lawnweeds100" at Yahoo.com.
Pete AI2V
Mike; I've only run into a speaker with an open filed coil twice, and they were on newer speakers from the 1940s. One ...Arran — 12:48 AM
Arran Yes, this is my plan for now and what do I got to lose, this is not even the speaker from this radio, but one o...morzh — 10:44 PM
Mike;  I would unwrap the field coil, and see if maybe there a break near one of the ends, like where the coil wire att...Arran — 10:23 PM
...and this is what I did. I fed a little LT into the screwholes with a small brush, and a little on the rim next to the...morzh — 09:52 PM
Philco 40-120C Restoration
I combined the two 40-120C threads together as we like to keep the discussion of the same radio together. It helps with...klondike98 — 09:36 PM
Philco 40-120C Weak, Distorted Ouput
Just checked were I buy tubes price is four dollars. So living in Florid we have a local source for tubes. David    David — 09:14 PM
The higher voltage may be due to higher mains voltage. My mains run 120-125AC when the set was new mains would be 110-11...David — 09:09 PM
Thank you for your reply. I pulled a speaker from a Philco 41-221 and received the same result. I used a signal tracer t...bluecap — 08:45 PM
Have you tried a different speaker? How did you trace the distortion? How do you know it is weak? What is the reference?...morzh — 08:33 PM
Amen to that! Every time I think I’ve captured them all, I realize that there’s another error. My goal is to finish with...jrblasde — 07:00 PM
