Wood veneer species ?
Hi again! Icon_wave
First of all, a big THANK YOU to Ron for answers my knob questions. Icon_thumbup
Here's my next query; what is the wood species on the 41-788?
Mike
Looks like Mahogany to me..
-Keith
46conehead Wrote:Hi again! Icon_wave
Mike
On what part of the 41-788's cabinet? From the photo in the gallery it looks like French walnut on most of it, possibly stump walnut near the knobs if that portion is real, do you have an photos of your cabinet?
Thanks, I believe your answer has gotten me close to what I needed.
Took me awhile to research similar woods and get back to you. Thanks again
Mike
Must say, Arran has a good handle on wood varieties.
Rogers Majestic R-646
Vlad; I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM
Thanks RpdB I don't think there's much difference with interstage transformers of different models other than dimersion...Vlad95 — 03:27 PM
Vlad; I looks like your set has the same problem that mine did, both a bad output transformer, and a bad audio inters...Arran — 03:21 PM
Ouch! Not often the secondary takes a hit. Wish there was a better solution. I have a good interstage transformer but it...RodB — 02:59 PM
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
No, you are wrong, because you did not know the details. Unfortunately, only ONE winding out of six is intact in both t...Vlad95 — 01:14 PM
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM
Thanks RodB for the help. But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM
There are currently 1002 online users. [Complete List]
» 3 Member(s) | 999 Guest(s)
