correct 42-380 color/did i kill it?
just picked up a 42-380 today at a local flea market. it's complete, paid 50.00 for it. which i think is a good deal. it was plugged in and slightly working at the flea market. i got it home and was able to get it to tune in am stations by turning the volume all the way up. then i unplugged it and moved it plugged it in again and heard a sizzling sound. quickly unplugged it, think the sound was coming from the transformer. hope i didn't kill it. sorry i've gotten off track here what i would like to know is about the cabinet (any thoughts on the sizzle problem please advise) it's in very good shape. just needs to be cleaned with 0000 grit steel wool and refinished. what would be the correct color of minwax stain to use? thanks for any input on both problems!!
Hi,
That sizzle is your transformer. No doubt the electrolytic capacitors are shorted and putting a direct short to your transformer. It could be fried but it maybe ok. I've heard them do that before and they were ok. A meter check could possibly tell you. Please don't plug it in again! This is for your own safety. The radio needs to be totally recapped and inspected for other defects. In answer to the cabinet I think using 0000 steel wool and GOJO hand cleaner (not the gritty kind) cleans a radio up very well. I think you will be suprised at the results. If you need a stain I would go with Special Walnut. Ron may have a better idea. The 380 is good playing radio when restored.
Hope this helps
Philco did not use stains. Toning lacquers were used to apply "color" to the cabinets.
Hi, This may seem like obvious advice but I know how bad these radio can look after years of sitting around . I taken some real beaters that started out looking like they need refinishing and just cleaned them.Start with a soft paint brush and get the dirt out of the cracks .Be careful not to wreak anything , take your time .Next just use a soft damp cloth and wipe the thing down rub the dirt off. Do not get bare spots wet as it will get under the finish. Stop . Come back in a couple days and do wet cloth routine again.Water will eventually take of most stuff (even the finish if it gets under it). Last use some murphy' oil soap and buff by hand . See where you are at and what you think.You can all ways refinsh it but original finish is great even if it is beat up some.If it is to far gone then find one that isn't for 50 bucks and save yourself alot of work.Redoing the finish on these correctly is an operation.Usually they can be cleaned up even when it looks bad. Any way it is not the type of thing that can be cleaned decent in one pass with out chemicals.
I have recaped one of these and it has worked for years now with original tubes.If you pay to have someone do it for you I am not sure what a fair price is. Make sure you know what that is before you go that route. Have a good one !
Yeah, looks really dense. It is amazing how many sets of brand A were made by Brand B. I have Mid 50s RCA that is an e...MrFixr55 — 10:15 PM
Philco 60 Power Trans
I am not 100% sure of the reason, likely due to the depth of the winding, but on HV windings of a power transformer and ...MrFixr55 — 10:04 PM
46-1213 Schematic Question
Hi Larry, Great idea on the fuse!  Place in the line at the power switch.  Best between the cord and switch.  While ...MrFixr55 — 09:59 PM
Philco 47-205
Just picked up the second of the three Leatherette Philco's. (My second one in the three-radio series) Nice shape, all p...slford310 — 09:18 PM
Dan; I take it that you mean that the H.V winding reads 157 ohms on one side of the center tap, and 177 ohms on the o...Arran — 07:00 PM
New find. 91X code 225
Hello, I have a Philco 91 code 121 (one speaker). I found more info here that might be of some help. Might want to fo...dconant — 06:42 PM
Hello, The HV winding on the trans is about 700 volts no load. My meter (Fluke 115) only reads to 650 volts so I meas...dconant — 04:18 PM
Thanks all. To be honest I don’t know what to make of it being in this cabinet style but I like it a lot. I specifically...pdieten — 12:47 PM
Nice grab! It appears to be a 19X cabinet. This wasn't unusual. Philco often retrofitted to other cabinets as invento...GarySP — 12:32 PM
I would certainly write down step-by-step the progression of disassembly of the works, and probably cuss out the electri...GarySP — 12:18 PM
