Philco Electrolytic Can Caps
Threads: 13
City: Ambler, PA USA
Folks:
Came across a bunch of new old stock Philco branded stud-mount aluminum can caps. Checking the part number on the Repair Bench site, I can't identify them.
Nine are marked 30-2511S, 40mf@450v, and five are marked 30-2368S, 18mf@475v.
Application? Value? Any chance they're still serviceable, or shall I assume they're restuff candidates?
Mike Koste
Gobs of Knobs
Zucksville, PA
Threads: 18
I wouldn't trust anything that old, but yes, you could re-stuff them.
Threads: 92
City: Clayton, NC
Definitely would not trust them. As Dave Cantelon once said, "Would you drive your antique car on NOS 70 year old tires?"
Can't find the 30-2511, but in the 1941 Philco parts catalog, the 30-2368 is listed at 18 uF, 475 WVDC.
Agree with all in that I wouldn't use them. But, yes, they would make great restuff candidates. Just be mindful of that boric acid solution - it won't hurt you if you get it on your skin, but it will squirt out if the seals on the can are still in halfway decent shape.
Threads: 92
City: Clayton, NC
And since you mentioned seals. We call various forms of gaskets and o-rings "seals," but we never see seals basking in the sun or swimming in the ocean and call them gaskets or o-rings.
And why do we say that a door is "ajar," but we never say that a jar is a door.
Why, why, why......?
Threads: 54
Other then as candidates for restuffing they are somewhat interesting as a curiosity if they still have their original packaging. They could be put to use but the contents would very likely find some way of leaking or drying out if they haven't done so already.
Threads: 40
City: Las Vegas, NV
(03-16-2012, 12:05 AM)TA Forbes Wrote: And since you mentioned seals. We call various forms of gaskets and o-rings "seals," but we never see seals basking in the sun or swimming in the ocean and call them gaskets or o-rings.
Why, why, why......?  Ok they should be called packings. Buy I've never seen one fill a suitcase either.
John
Las Vegas, NV USA
Threads: 573
(03-15-2012, 09:45 AM)ekimetsok Wrote: Folks:
Just so no one gets confused:
mF (a millifarad) = 1000uF=0.001F
18mF is 18,000uF
So you probably meant 40uF and 18uf (microfarads) respectively.
They were not making this size caps in millifarads back then
(Not that it matters in this case - you're going to restuff them anyway  )
Threads: 117
Whew! This thread went south in a hurry didn't it!!? Mike, I'm still interested in purchasing a full matching set of original Crosley model 516 bakelite knobs if you ever have any? ( The full Set),... If you know what these knobs are, and ever find any: hit me up at: www.texasvintageaudio.com
Best Regards always!! ol' Tex.
Philco model #20
Hi Rick,
The volume control on the Model 20 has 2 sections and does 2 seperate things:
One part of the control, ...MrFixr55 — 10:30 PM |
Philco model #20
Hello again fellows , well I powered up the set this evening after I had changed every cap and resistor in this set and ...onlyrick — 09:34 PM |
Yes - better it happened on the repair bench than returning to the owner.
The other question is - do I also dissect a...EdHolland — 09:08 PM |
That's a bummer but get them now. Paul BPaul Philco322 — 08:27 PM |
I completed the insulation on the cabinet interior (Al foil and hi temp silicone rubber), and reglued the speaker gasket...EdHolland — 06:18 PM |
Tim - Photos of 8 octal tube sockets. (Top and bottom)
Send me a PM if you're interested.RodB — 04:11 PM |
VTVM meter moves when my hand is next to it & not on
Haha! I hope so. It seemed rather lost and forgotten languishing in the frozen Northeast of England.EdHolland — 02:36 PM |
Ed - it's in the Cayman's enjoying the good life.RodB — 02:14 PM |
Static electricity - but the other chaps beat me to it again. I've seen this before with analogue meters.
I've also ...EdHolland — 01:56 PM |
Hi Paulo,
Welcome to the Philco Phorum.
I can see why you want to find good reproduction parts. That is a bea...MrFixr55 — 11:10 PM |
