Hit the wall with my 1230
I've had my 47-1230 out for repair for months... The company is an authorized Philco dealer, and have replaced a few parts, but when they replace one, they find another that is bad. But, I'm fine with that, as long as they are getting somewhere.
Unfortunately, the company working on it is going out of business. Does anyone here know of anyone in Eastern PA that may be able to finish up the chassis for me? I've got the schematics, and can/will acquire required parts, but I need help getting it all together.
Thanks.
I might know somebody. Where are you?
An authorized Philco dealer? Who authorized them? Philco basically ceased to exist around 1980. As for one part failing after the other well it was built in 1946-47, if they really knew what they were doing they would replace all of the capacitors and the majority of the resistors rather then using a piecemeal approach. If the company working on it is going out of business I'm not the least bit surprised, they have one of two problems as I see it:
(A) Their technicians are young and know very little about servicing tube equipment.
(B) Their technician is an old school repairman who doesn't realize that this is 2012 and not 1952, and that all of the paper caps in that set are failing or are about to fail after 65 years of service.
I have been into contact with someone who has a similar problem, he sent his chassis off to some "repairman" to get his set fixed but this repairman could not be convinced to restore the set, he only wanted to replace what is immediately wrong with it. I don't know how some technicians were conditioned into this form of thinking but simply replacing the leakiest of caps in a 1931 Westinghouse is not going to cut it.
I agree, Arran... I think that was the case here.
(03-29-2012, 10:43 PM)7estatdef Wrote:  I might know somebody. Where are you?
Near Allentown. Thank you!
I've seen pictures of that 1230, it is in great shape. Way better shape than mine.
No doubt whoever decides to give a hand will have fun and the final result will be a fantastic player.
-Mars
Philco 37-116 Cabinet Repair
It looks to me like the structure under the veneer may have expanded from humidity cracking the veneer on the surface. W...Arran — 09:42 PM
Help with Supreme 599
Iam only getting 4vac out of the tranny For the 80 filament. The line rheostat Looks fine and the tranny is getting 11...daveone23 — 08:45 PM
Rogers Majestic R-646
Transformers rewind? It's very easy! If you don't have round eyes  8-) Vlad95 — 01:55 PM
I found a broken wire from the end og the 300 ohm line adjust to the transforner but i dont think its needed. The transf...daveone23 — 11:43 AM
Philco 38-10 Tuning Condenser
RodB I have been using pure Vaseline for a long time for thick lubrication of home radio devices. The main reason is t...Vlad95 — 10:58 AM
Vlad, your comment about Vaseline brought a thought. Does anyone know the long term affect on using silicon grease on t...RodB — 10:34 AM
Arran, didn't notice the specifics for the caps. What's the code going to get me? I'm working on restoring a Philco 50-9...RodB — 10:26 AM
I managed to get the gears lined up and the springs back in. Much easier than it thought. Putting a thin wire down insid...dconant — 09:52 AM
Rod, Mrfixr55 and everyone else thank you very much for all your help with this radio thus far. Today will be more testi...osanders0311 — 09:26 AM
Thanks for the reply Vlad95. I can't even see the balls let along try to remove them. The grounding forks are going to p...dconant — 08:03 AM
