42-123 output trans. replacement
Does anyone know of a replacement output trans, new or interchangable from another model that would work in a 42-123? 900/1100 CT.
Thanks, Todd
Those 1LA4's have a very high plate impedance. 25K each so what you are looking for is a transformer 50K ct to 8 ohms
In some cases the old paper caps can be replaced with ceramic caps, with values such as .001 uf, .005 uf, .01 uf, and ma...Arran — 06:50 PM
Vlad; I would tend to agree, I only suggested the loop antenna connections since he was already looking at the end of...Arran — 06:18 PM
Rod thank you for helping to understand the paper caps and offering the bumblebee caps. I have already ordered film caps...osanders0311 — 03:55 PM
Bob, this is the wrong sequence to look for problems and setup circuits. Always start checking the signal path from the...Vlad95 — 12:19 PM
Philco J1720 stereo and record player with reverb
The above link takes you to the Delaware Valley Historic Radio club. They are not too far from you and may have sugg...klondike98 — 11:49 AM
Tucker Movie Prop car
Richard: Did you ever check with your friend? About once a year I try to verify if Mr Rhoades really worked on the r...WrenchMonkey — 09:22 AM
>>when turning the knobs This is very broad. There are knobs for tuning and knobs for volume, and possibly f...morzh — 07:36 AM
Thx Arran, I will check the antenna connections. Right now the loop is alligator clip connected to the chassis since you...klondike98 — 03:58 AM
Bob; I was just thinking that maybe the 1R5 tube doesn't like being operated at 1.2 volts on the filament, though you...Arran — 12:56 AM
So I just purchased a Philco J1720 stereo and record player. That has some static when turning the knobs. Wanted to see ...PhilcoJ1720 — 12:26 AM
