Trim on 42-124
Does anybody know if that was painted veneer or bakelite? I have one that is missing all of the trim on the bottom of the the radio. On that note also does anybody reproduce the bakelite estcheons around the dial scale. I have a couple of radios that need replacement.
thanks
Chris
Hi Chris,
You might check out Larry's site:
http://www.antiqueradioknobs.com/partlistings.html
Carl
Northern Panhandle, WV
The dial bezel is a plastic called Tennite. It is an early plastic that warps over time. Try Larry.
Thanks guys I e-mailed him. Hopefully he can help. I also need the covering around the dial scale on a couple of sets.
thanks
Chris
Chris - is that the set you bought or traded from me some time back? That bottom trim is wood. Very thin, but thicker than veneer. Had I kept the set, I was going to go to Lowe's and find the thinnest Weyerhauser (sp?) Choicewood I could find, cut to size, apply and heavily tone it extra dark walnut or Van Dyke brown, which would have replicated the original trim quite well.
Sorry Chris - thought you meant the dial surround, not the bottom of the cabinet trim. Icon_confused
Ron,
Yes that is the set. I have recapped it and am ready to try it. I thought that it was tennite and am glad it is wood. Will have to check out lowes for the wood.
Chuck,
No problem I also need the tennite dial surround. I have two sets that have badly damaged ones. I e-mailed larry but no response yet Icon_cry
thanks guys,
Chris
LOL!! Well Arran, if you do dive into it and come across any advice on dealing with accessing components let me know. I...klondike98 — 11:56 PM
Bob and Gary; I have the further complication on the Phillips that they decided to use some 200 volt rated paper caps...Arran — 10:05 PM
Thx Arran & Gary. Yes its super crowded in the chassis and I've debated whether to try to restuff caps or not. I t...klondike98 — 07:40 PM
That's got to be one of the tightest conglomeration of components I've ever seen! I wonder how the line workers felt bu...GarySP — 05:46 PM
Bob; I think that the Phillips was actually manufactured in Canada, though they may have imported many of the compone...Arran — 02:28 PM
I've started replacing the electrolytic caps now. As Arran mentioned, they are housed under a metal strap. Here's a ph...klondike98 — 12:22 PM
Thank for that info Arran! Very interesting. Phillips and Motorola must have made some type of marketing deal back then....klondike98 — 11:49 AM
46-1213 Schematic Question
Good idea on the fuse. These old transformers need extra protection.RodB — 10:02 AM
Hello Larry, Well, anyway I can contest about noisey grounds in my living room when I am using one outlet in my house a...radiorich — 08:03 AM
RodB & MrFixr55, Thank you both for the great replies at my questions, I appreciate the help very much.  As suggest...MissouriLarry — 07:04 AM
