All Wave Aerial Transmission Line ?
I was intruiged by the extra antenna connections on the back of my 610 - there is a note that states that I should connect some kind of antenna - The "All Wave Aerial Transmission Line" - to unleash my set's full potential - and clearly at some stage there was a factory option that could be added.
Is this something worth trying to duplicate ?
Maybe I'd be better off just making a conventional loop antenna ?
The radio works nicely just with a (not very) long line antenna but struggles to pull in some more distant stations. I'd be interested in learning more if anyone has any information or experience with this.
I'm really enjoying the set and use it pretty much every day.
(04-03-2012, 02:24 PM)chrisc Wrote:  I was intruiged by the extra antenna connections on the back of my 610 - there is a note that states that I should connect some kind of antenna - The "All Wave Aerial Transmission Line" - to unleash my set's full potential - and clearly at some stage there was a factory option that could be added.
Well, IMHO nothing beats a 2' X 2' tuned loop as long as you're not down in the cellar for A.M. broadcast. Nice and directional and all that good stuff. Long wire outside for S.W. or possibly a dipole, although they get tricky, and anything outside needs a lightening arrestor and nice big knife switch to try to protect the radio when the weather turns. L.W. is I dunno, not sure there is anything happening there in North America but correct me if I'm wrong. A nice thick wire to a stake driven well into the ground for a ground is always nice for a transformer set if you can do it.
Well that's a start.
OK - Thanks - I think I'll go with the tuned loop as I've been hankering to build one anyway. I was just curious about what the factory accessory actually was.
ChrisC
The extra connections are for a dipole antenna called the Philco All-Wave Aerial. This dipole used a balun at the antenna to feed a twisted pair lead-in, which in turn connected to the two screws in the back of your 610. Most other 1936 Philco models were similarly equipped.
In 1937, Philco changed the name of the outdoor antenna to the Philco High Efficiency Aerial. You can read a little more info on Chuck's site:
http://www.philcorepairbench.com/mystery/40-6112.htm
Thanks, Ron ! It's really interesting to learn what this thing was / what they were trying to do. In my situation I think I'd be better off making up a basic loop antenna - should be a fun project.
Chris
Nice job on the battery, Bob. Can the box be opened to replace the 9 volters?RodB — 11:32 AM
Thank you for the detailed response MrFixr. To clarify, the hum starts when the tubes are fully warmed up, and goes a...sq65 — 09:15 AM
MrFixr The chassis, if there is no ground pin in the AC plug, due to the Y-caps from L/N to the chassis, is at 60VAC re...morzh — 08:47 AM
schematics
thanks I'll try the polar caps seperatelymseno — 07:38 AM
Hi SQ55, A strange issue indeed!  Just so I have you straight, on a dim bulb you get normal operation after the set warm...MrFixr55 — 12:44 AM
schematics
I think mseno is talking about cap# 27 which is a multisection but in a paper tube. In cases like that I've usually be ...klondike98 — 11:25 PM
schematics
Ohrenet  :roll: For their price I would chase a fly in a field.  :twisted:Vlad95 — 11:21 PM
A bit more work on the Motorola. I got the repro battery together right up until I realized the snap clips on the top o...klondike98 — 10:45 PM
schematics
Often restuffed. If a twistlock, Hayseed Hamfest makes modern replacements. morzh — 09:18 PM
schematics
Looking for a multi-sectional 8+16 mfd cap. Can't find any suppliers that carry it.mseno — 08:45 PM
There are currently 1146 online users. [Complete List]
» 1 Member(s) | 1145 Guest(s)
