Philco 38-60 working
Picked this up from craigslist in Michigan.Had it shipped(double boxed) and it arrived safe and sound.It was missing the knobs and I will order some from Radiopup next friday.Repaired the dial lamp housing.It worked with a slight hum,so I replaced all of the caps including the hard to get one in the sub-chassis.While I was at it I replaced all the rubber gromment between the sub-chassis and the main one. Found some grill cloth at a fabric store and replaced the white sheet type material that was there.It works great and sounds fine on both shortwave and am broadcasts.It was indeed a pleasure to work on.Thanks for the help guys(Electrical phorum) and here are some pics....Doug
[Image: http://i1095.photobucket.com/albums/i474...to0132.jpg]
[Image: http://i1095.photobucket.com/albums/i474...to0130.jpg]
[Image: http://i1095.photobucket.com/albums/i474...to0128.jpg]
[Image: http://i1095.photobucket.com/albums/i474...to0126.jpg]
[Image: http://i1095.photobucket.com/albums/i474...to0127.jpg]
[Image: http://i1095.photobucket.com/albums/i474...to0129.jpg]
[Image: http://i1095.photobucket.com/albums/i474...to0131.jpg]
Looks good, its hard to find one with a finnish that nice. Was the 37-60 schematic the same?
Actually it wasn't I found a 38-60 which had the 2nd block cap with a .03 cap in the schematics in it by chance and was glad I did(laughing) Doug
Photo finish is in nice shape! You should be able to pull in some good shortwave broadcasts at night with your set, as the SW band extends to 7.4 MHz.
Yes I had the am station Wbal in Baltimore on listing to the Orioles game the other night 250 miles away it was cool!
Nice job on the battery, Bob. Can the box be opened to replace the 9 volters?RodB — 11:32 AM
Thank you for the detailed response MrFixr. To clarify, the hum starts when the tubes are fully warmed up, and goes a...sq65 — 09:15 AM
MrFixr The chassis, if there is no ground pin in the AC plug, due to the Y-caps from L/N to the chassis, is at 60VAC re...morzh — 08:47 AM
schematics
thanks I'll try the polar caps seperatelymseno — 07:38 AM
Hi SQ55, A strange issue indeed!  Just so I have you straight, on a dim bulb you get normal operation after the set warm...MrFixr55 — 12:44 AM
schematics
I think mseno is talking about cap# 27 which is a multisection but in a paper tube. In cases like that I've usually be ...klondike98 — 11:25 PM
schematics
Ohrenet  :roll: For their price I would chase a fly in a field.  :twisted:Vlad95 — 11:21 PM
A bit more work on the Motorola. I got the repro battery together right up until I realized the snap clips on the top o...klondike98 — 10:45 PM
schematics
Often restuffed. If a twistlock, Hayseed Hamfest makes modern replacements. morzh — 09:18 PM
schematics
Looking for a multi-sectional 8+16 mfd cap. Can't find any suppliers that carry it.mseno — 08:45 PM
There are currently 1130 online users. [Complete List]
» 1 Member(s) | 1129 Guest(s)
