dial light for 40-190
Hi! I would like to know the correct bulb to put in this model is it #44 or #47 or a different #. I would like to get it as bright as possible Icon_confused
RT,
The two pilot lamps in the 1940 Model 40-190 are Philco Part No. 34-2064 (from the service bulletin parts list) which are equivalent to the standard number 44 lamp.
Cross references on Philco pilot lamps and standard numbers are on my site: http://www.philcorepairbench.com/lamps.htm
Chuck Thank you for the reply I only see one bulb in the tuner not two could someone have takin a bulb and socket out maybe that's why it looks dim? Icon_confused
Oops . . . sorry, only one lamp. Icon_confused Icon_confused
Must have flipped to previous bulletin for the 40-165 which does have two lamps.
Brain Cramps occuring more frequently nowadays . . . .
If you have the wrong lamp type in there which takes more current or is of a higher voltage rating, it will appear dimmer than the required type.
Hi Chuck thanks again for the speedy reply a #44 is now mandated for the radio Icon_lol
Hi! Chuck went and got a box of #44 bulbs pulled the old bulb out It was a Tung-Sol #44. Funny the tip of it was painted BLACK and the rest was frosted. Anyway put the new bulb in and saved the old one, My mother worked at Tung-Sol in Bloomfied NJ. for many years So this will stay with the set Thanks again PS I need a speaker for a 40-150 could you tell me what models are inter-changeable with this Philco And where I might be able to purchase an original one. Dan Icon_smile
Hi again,
That EM speaker type, 6-1/2" in diameter, is an odd size and was not that universally used.
The part number is 36-1483. The field coil is 1,100 ohms D.C., the voice coil is 5 ohms, and the speaker has a hum-buck coil in its design (see schematic).
This speaker can be substituted by Philco part numbers 36-1551 and 36-1519, both with same specs.
Your original part (or the subs) are also used in these models:
40-155, 41-250, 41-255, and 41-256.
Happy hunting,
Chuck
Need Help to ID this radio 11 tube Philco
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
48-482 rear panel help
Welcome to the Phorum, keithchip! How far you take a radio on cabinet restoration is a matter of personal preference. ...GarySP — 11:28 PM
I've recently finished the internal restoration of a locally purchased Philco 48-482. The cabinet is in ok shape except ...keithchip — 10:28 PM
Welcome to the Phorum, Ken! Lots of help here for all of your restoration questions. Take care and BE HEALTHY! - Gar...GarySP — 07:59 PM
Thank you. I went to your online library and found 2 schematics. I will download and compare to components!Ken D. — 06:31 PM
It is a 16B tombstone.morzh — 06:13 PM
David - sorry, I reread your post and finally saw THD - now the % figures make sense. Thanks for explaining. The PSU...EdHolland — 06:06 PM
Hi Everyone, New member but have been reading this for awhile for tips! Vaccum tubes were before my time so bear with ...Ken D. — 06:03 PM
My Philco 37-116 Restore
Thank you MrFixR55, I appreciate your comments very much. I do not detect much hum if any so I will be staying with the ...dconant — 05:15 PM
Hi DConant Yes, you can replace chokes with resistors.  You do stand the risk of increased hum.  the solution is to inc...MrFixr55 — 04:23 PM
