Pilot Cathedral?
I picked up a cathedral radio yesterday and it's a 4 tube set (tubes: 47, 48, 57 and 80). The chassis is flanged and bolts in like other Pilot sets I've see and there is a round Pilot sticker/logo on it, but the ID label isn't on the chassis back. I did the tube layout search and didn't come up with a 4 tube Pilot, just a LOT of other sets. I can't imagine someone would have put a Pilot speaker in a non-Pilot set, but you never know! Anyone have any thoughts, ideas OR can ID this set?? I'll try to attach some pictures. No, I didn't pay $100 :-)
Thanks!
David
Well it does have 1934-35 RCA/G.E style knobs so those don't belong. I can't comment on the speaker but if it looks like someone spliced the cable going to it that's a good sign that it is a replacement. The tubes installed do not make sense, the 80 is a rectifier which is normal, but the 47 is a 2.5 volt power output pentode, the 57 may make some sense as it's also a 2.5 volt tube used as a detector/amplifier, but the 48 is a 30 volt power output tetrode popularly used in 32 volt DC sets so that tube couldn't possibly work in this set.
My bad. The tubes are: 58 57 80 47 (not a 48).
Follow the link below to see if the listing has a hit.
http://www.grillecloth.com/sylvania/tube...ubmit&db=5
rghines1 - I spent 2 or three hours last night going over that list and then trying to search for matching pictures on http://www.radioatticarchives.com/
but I had no luck at all. It's really bugging me!
Hello: neat set! Try the below link and plug in the results from your search on the grillecloth.com finder.
http://www.radiomuseum.org/
There were many off-brands made back then using chassis manufactured by other companies.
Hi David,
Been there done that. Might want to find a circuit that is close and use that as a rough draft. I've got an odd set I got a while back that I never could find much on with the same layout as yours. This one the power transformer was shorted so it got replaced with a new one. The RF coils where starting to unwind those got rewound ect,ect,ect. Anyway it's up and running.
http://www.flickr.com/photos/53710524@N0...hotostream
Thanks! When I get some more time, I'll begin to research some more.
Well I never determined what make it is, but it's got a dandy Pilot speaker! LOL!!
I've had the same radio for 30 plus years. It says Pilot #51 on the back of mine. I've been missing one of the knobs since I got it but it plays great and has 98% of its original parts. I've never found out much about the radio either.
Its a Pilot, sold under the Twin Coupler brand
12' Philco
12' Philco
Hickok AC51 tube tester
Arran If the wire inside cans is the gauges you mentioned, the sole reason for that would be mechanical, to stiffen t...morzh — 12:56 PM
12' Philco
Rod, Yes, I know, but the Giant Philco is not around anymore either, so I go by whoever was alive fairly recently. H...morzh — 12:54 PM
Note that no power cord, power switch, or power transformer switch are shown. That (along with my experience with full s...DaleHCook — 07:09 AM
A pair of wire strippers can give you an idea of what the existing gauge of the wire leads are in the IF can, I think it...Arran — 06:07 AM
My last cabinet for this year
There are currently 5439 online users. [Complete List]
» 3 Member(s) | 5436 Guest(s)
