Replacement Battery Specs for P608-6L for a Model 48-141
I am in the process of getting my fathers old Philco 48-141 up an running which is a batter powered raido. The specs on this site show the above battery pack. http://www.nostalgiaair.org/Resources/624/M0013624.htm . However, they don't seem to me made anymore Icon_smile I had it running before using a very simple DC regulator I built using a transformer, a bunch of old zener diodes and some batteries. However, I am now wanting a more permanant solution using an actual battery.
From the schmatics, it looks like I need taps with 85, 5 and 1.5 volts. While the 5 and 1.5 are simple, the 85 my need a power inverter to boost the voltage off of a standard 12v battery. Has anyone ever done this before? If so, where could I find the schematics.
I am also i need of the battery plug and socket. The AC cord is original but I the plug is broken and I would like to replace it. I also need the socket for the battery pack that I would like to put into the case.
The final goal is to make this chargable using the AC adaptor or a 12V DC source from a car or a solar array....Yes, I know I am crazy for this but who else has a solar powered tube radioIcon_smile My father use to run it off of their windmill that was also use to pump their water.
Ken
The battery you need is a P60B6L, which is a 1.5 and 90 volt pack, measuring
10 3/4" x 2 5/8" x 6 1/4". So, all you'd need are those two abovementioned voltages. The 5v takes care of itself by way of the circuit.
I'd be glad to build you a battery, but I suspect you'll want it sooner than I could deliver it, as I'm swamped with other battery orders. I CAN, however, build you a socket if you'd like. All you'd need to do is lash wires to the respective solder islands.
Oh, I may have a large 4 pin plug in my mess of stuff, too. Let me know via email if you're interested.
Bill
New Philco Repair Bench
I'm not sure why that wire wasn't covered in the video. I'm pretty sure the 6A8 won't work until that pin is grounded. Y...RodB — 09:47 PM
You'll have to forgive me, I am not sure what you mean.  Can you explain what you are really saying.  If anyone does not...georgetownjohn — 08:05 PM
Those are details better left to the ones who know. Maybe you disconnected the wrong end of the wire.RodB — 06:22 PM
Maybe this is starting to make some sense in my hard head.  Is this why the wire in question was not in the great Ron Ra...georgetownjohn — 04:34 PM
I was correct with the 6A8 pin connection's, 7 and 8 are connected to ground as well as the tube shield (the broken line...RodB — 02:41 PM
What does the dotted line representing that surrounds the tube in the schematic?georgetownjohn — 02:17 PM
Hello John, I have been there either label got lost or was not labeled ! Sincerely Richardradiorich — 02:15 PM
Sorry, it is a Philco 37-640.  Does that help?--Johngeorgetownjohn — 02:14 PM
