Missing Philco Speaker
Hi
I am now working on a Philco 37-640 that came without its original 8"speaker. Unfortunatly it uses a different type speaker from that used in other models, like the 37-620 or 630's or 60's series This speaker has 4 wires coming out it, going to the set. It Also has a center tap out of the power transformer. The number mentioed in the Philco data sheet for this speaker was Philco R 34 or H25. Does anybody out there have any information about such a speaker i.e coil size, 8 or 4 ohms etc. I would like to avoid using a PM type and keep the set as original as possible. Thanks
Try http://www.oldradioparts.com/
Kind regards,
http://home.comcast.net/~suptjud/
"Life is simpler when you plow around the stump."
With regard to the speaker, unless the cone is so brittle that it crumbles as soon as you touch it I would try to repair...Arran — 04:07 AM
That silver can capacitor is an aluminum electrolytic. You should replace it with an aluminum electrolytic with the valu...RodB — 11:46 PM
There are currently 396 online users. [Complete List]
» 4 Member(s) | 392 Guest(s)
AvatarAvatarAvatarAvatar
