Mica Values for Philcos.
Philco used some mica capacitors with values that are not available today, or might be hard to get.
How far off of the values specified in the schematic and parts list can you go before performance is affected?
For example, in the RF deck of a 37-116, there are 40 pf, 25 pf. My new mica caps are off by 1 pf (39 vs 40, 24 vs 25), and I would assume that is not worth worring about, but I could be wrong about this assumption.
How far off can you substitute a value before you affect performance negatively?
Frank
Mica's from that era are going to be rated for 10% at best, so you're probably ok being only 1 pF. off on each value. Your subs translate to 2.5% for the 40 pF. and 3.5% for the 25 pF. cap.
Slight wiring differences on the production line would be at least a pF or two due to lead dress anyway.
You could avoid this problem by purchasing the exact values of these capacitors. http://www.justradios.com has these capacitors.
Need Help to ID this radio 11 tube Philco
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
48-482 rear panel help
Welcome to the Phorum, keithchip! How far you take a radio on cabinet restoration is a matter of personal preference. ...GarySP — 11:28 PM
I've recently finished the internal restoration of a locally purchased Philco 48-482. The cabinet is in ok shape except ...keithchip — 10:28 PM
Welcome to the Phorum, Ken! Lots of help here for all of your restoration questions. Take care and BE HEALTHY! - Gar...GarySP — 07:59 PM
Thank you. I went to your online library and found 2 schematics. I will download and compare to components!Ken D. — 06:31 PM
It is a 16B tombstone.morzh — 06:13 PM
David - sorry, I reread your post and finally saw THD - now the % figures make sense. Thanks for explaining. The PSU...EdHolland — 06:06 PM
Hi Everyone, New member but have been reading this for awhile for tips! Vaccum tubes were before my time so bear with ...Ken D. — 06:03 PM
My Philco 37-116 Restore
Thank you MrFixR55, I appreciate your comments very much. I do not detect much hum if any so I will be staying with the ...dconant — 05:15 PM
Hi DConant Yes, you can replace chokes with resistors.  You do stand the risk of increased hum.  the solution is to inc...MrFixr55 — 04:23 PM
