What is the correct resisior wattage
I'm working on a 41-285F that is coming along nicely. I'm about to replace the out of spec resistors and would like to know what wattage rating I should use. For example, there is one 10M ohm resistor that passes less than a volt, would a 1/4 watt rating be too small or should I go higher? The original is pretty small in size.
Rick
That 10,000 ohm resistor can be a 1/2 watter. Most resistors are at least 1/2 watts, other than any power resistors. 1/4 watt resistors were not "invented" then.
A 1/4 watt resistor will NOT have the voltage rating that a 1/2 or 1 watt resistor has. A 1/2 watt resistor has about a 250 MAX voltage rating, so keep this in mind.
Thank you Chuck,
This is the first Philco I've worked on and it's been a long time since I've worked on a tube radio. I'll search for a 1/2 watter.
Rick
Need Help to ID this radio 11 tube Philco
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
48-482 rear panel help
Welcome to the Phorum, keithchip! How far you take a radio on cabinet restoration is a matter of personal preference. ...GarySP — 11:28 PM
I've recently finished the internal restoration of a locally purchased Philco 48-482. The cabinet is in ok shape except ...keithchip — 10:28 PM
Welcome to the Phorum, Ken! Lots of help here for all of your restoration questions. Take care and BE HEALTHY! - Gar...GarySP — 07:59 PM
Thank you. I went to your online library and found 2 schematics. I will download and compare to components!Ken D. — 06:31 PM
It is a 16B tombstone.morzh — 06:13 PM
David - sorry, I reread your post and finally saw THD - now the % figures make sense. Thanks for explaining. The PSU...EdHolland — 06:06 PM
Hi Everyone, New member but have been reading this for awhile for tips! Vaccum tubes were before my time so bear with ...Ken D. — 06:03 PM
My Philco 37-116 Restore
Thank you MrFixR55, I appreciate your comments very much. I do not detect much hum if any so I will be staying with the ...dconant — 05:15 PM
Hi DConant Yes, you can replace chokes with resistors.  You do stand the risk of increased hum.  the solution is to inc...MrFixr55 — 04:23 PM
