Looking for correct speaker for 46-1201
Hi all-
I never knew this was here until today! I have been restoring a 46-1201 "Bing Crosby" on and off for a while, and I think I got it going well with new caps and a couple resistors.
My problem is that the speaker must have been replaced a long time ago with something else (spliced wires that do not match as well as the actual mounting screws). It works OK, but I know it should sound better at lower volumes. Does anyone have a working 5 wire speaker to sell from that era?
thanks
Chris
Hi,
The Philco part number for the electro-dynamic speaker in your radio-phono is 36-1587. You might try PlayThings of Past, Gary Schneider's website for used parts: http://www.oldradioparts.com
Good luck Icon_smile
Chuck
With regard to the speaker, unless the cone is so brittle that it crumbles as soon as you touch it I would try to repair...Arran — 04:07 AM
That silver can capacitor is an aluminum electrolytic. You should replace it with an aluminum electrolytic with the valu...RodB — 11:46 PM
There are currently 391 online users. [Complete List]
» 4 Member(s) | 387 Guest(s)
AvatarAvatarAvatarAvatar
