Coil over tubular capacitor
One thing I've noticed Philco doing is winding a coil over a tubular capacitor. I've seen it in the 46-350 (L1/C26) and also in the 48-475 (no coil #/C317). Perhaps this is done in other models as well. Question is: How critical is this combination, i.e., does the cap act only as a form for the coil, or is the design such that it relies on the proximity of the coil to the ground shield of the cap? If the latter, is there a secret to recapping this combination?
Hi
This cap-coil combination was used in many Philco receivers, chiefly right after the war. It serves as an IF trap in the B- circuit. Chuck has an extensive write-up on this subject on his website:
http://www.philcorepairbench.com/tips/svctip37.htm
In practice, you can usually eliminate the cap-coil combo by replacing the capacitor itself, leaving out the coil, with no ill effects. However, you may retain the coil if you wish.
I pulled the tube out and it's shorted from pin 1 to pin 2. I suppose that's the problem...sq65 — 08:12 AM
bob  Nice work on battery . If you don't. Have terminals i have a few spares  Samsam — 02:12 AM
hello mr Fixr, for sure !! I have some radios that I need to make some batteries for too. Sincerely richardradiorich — 12:33 AM
Dittos, sweet b on the battery. Love the "9 Lives" logo, remembered from my childhood. Other neat ones are t...MrFixr55 — 11:24 PM
Hi Morzh, Dunno if the AC EMI caps are an issue. I never liked the concept but never had an issue with these causin...MrFixr55 — 11:21 PM
And no hum without the 7AF7? Not common but I am thinking heater - cathode short. This would introduce hum in this sta...MrFixr55 — 11:14 PM
There are currently 1246 online users. [Complete List]
» 1 Member(s) | 1245 Guest(s)
