Model 71
Hi Guys,
Check this one out.
A friend of mine found this in a junk shop for $35 a few months ago. He capped it out, changed the speaker wire(s) and it came to life. He decided he did not want it so I purchased it for $35. Did I do ok? Is this a rare bird or is it pretty common? Right now it is painted brown so tomorrow I am going to strip and see what is underneath. Just goes to show a guy never knows where an old bone will surface.
Bob
Yes, even painted, you did great for $35. Icon_thumbup
Gosh, yes, that is a great deal.
Thanks!
It's my first cathedral so I know nothing about them as far as production numbers, and where they line up high end to low end. All I really know is I like the looks of the 80B the best.
Looks like he got the replacement grille cloth from the same place as Foggy. The model 71 is the 1932 equivalent of a Philco 70, except it uses 6.3 volt tubes I think, and the cabinet is different of course.
It also has avc the 70 doesn't.
Good deal!!
Yes, a fantastic dealIcon_biggrinIcon_biggrinIcon_biggrin
M R Radios   C M Tubes
Hi Bob,
You did really good on the set.
Hopefully, the paint has protected the veneer underneath.
Worse case, it is heavily sanded in different directions Icon_eek
You can always re-veneer, that's a nice looking set.
Philco 42-1008 conversion kit
I read about a kit to convert the variable speed changer in the Philco 42-1008 into a single speed unit.  That would rem...alangard — 09:30 PM
Tim Well...a chassis is metal. Magnetic or not, it does not matter. A transformer has some hum to it. It is natural. Th...morzh — 08:40 PM
Hickok AC51 tube tester
I thought the 83 tube was bad because it looked white but it tests strong. Blue gassy though. I checked the fuse, it was...martinj — 08:37 PM
Shadow Meter Bulb
Ross I am not sure what current limiting effect the incandescent provides. They are two different parts of the sch...morzh — 08:31 PM
12' Philco
Bob Thanks for that photo. I have been looking for it, and I cannot find anythinmg on the web. I forgot it was here...morzh — 08:29 PM
Shadow Meter Bulb
I think after all has been said, I will use the same bulb that is specified for the dial pilot light which is a #55. I ...georgetownjohn — 07:31 PM
12' Philco
There was also this Philco! klondike98 — 07:25 PM
I expected a challenge and this is just part of it. But, it's also supposed to be fun, entertaining, informative and enj...TV MAN — 07:12 PM
Shadow Meter Bulb
Butting in here with a question. Since the shadow meter is connected directly to the 1st and 2nd I.F.'s wouldn't the met...RossH — 06:43 PM
Mike, Tim; you are about to enter the twilight zone. Doo doo doo doo, doo doo doo doo This is something alright. I'm go...RodB — 06:26 PM
There are currently 6019 online users. [Complete List]
» 1 Member(s) | 6018 Guest(s)
