Purpose of resistor in 37-670
Resistor #82, 5600 ohms seems to be just a huge load to the B+ supply; twenty watts of plate power spent on this resistor. What's the purpose of it? Prevent ice from forming on the chassis?
Since this is the B supply for the audio output stage, could it be part of a kind of constant source resistance stabilizer? That's all I can think of.
Pete AI2V
Pete AI2V
I am not sure but as many tube radios do, this one has low ohm resistors connecting Neg to the chassis, creating some negative biases (wherever they might go).
Now, they rely on the consumed current to create the bis and is a bit imprecise. In this case they created the exact divider, so the voltage is less dependent on the current (still dependent though but to a lesser degree).
May be to keep the B+ from soaring if the load is removed ???
I just thought of a likely reason for the resistor- it greatly increases the current through the speaker field coil and hence it affects speaker operation. Anyone have any comments on this idea?
Since both the resistor and field coil are open and the audio output is transformer badly unbalanced, I'll be installing a PM speaker temporarily; I'm going to leave the resistor out and limit the B+ with other more practical resistors (if necessary) and see what happens.
Pete AI2V
Bob, this is the wrong sequence to look for problems and setup circuits. Always start checking the signal path from the...Vlad95 — 12:19 PM
Philco J1720 stereo and record player with reverb
The above link takes you to the Delaware Valley Historic Radio club. They are not too far from you and may have sugg...klondike98 — 11:49 AM
Tucker Movie Prop car
Richard: Did you ever check with your friend? About once a year I try to verify if Mr Rhoades really worked on the r...WrenchMonkey — 09:22 AM
>>when turning the knobs This is very broad. There are knobs for tuning and knobs for volume, and possibly f...morzh — 07:36 AM
Thx Arran, I will check the antenna connections. Right now the loop is alligator clip connected to the chassis since you...klondike98 — 03:58 AM
Bob; I was just thinking that maybe the 1R5 tube doesn't like being operated at 1.2 volts on the filament, though you...Arran — 12:56 AM
So I just purchased a Philco J1720 stereo and record player. That has some static when turning the knobs. Wanted to see ...PhilcoJ1720 — 12:26 AM
I've started looking into the very weak and garbled reception in the set (I have the HS-62A version of the chassis seen ...klondike98 — 12:00 AM
Those last photos were not very good,so I  used one of my other cameras. This is more like the true colors of the radio....Dan Walker — 10:48 PM
If you look closely at the paper wax capacitors they probably have something like "outside foil" near the blac...RodB — 10:41 PM
There are currently 1063 online users. [Complete List]
» 1 Member(s) | 1062 Guest(s)
