Nobody else wanted it...
Well since it was in the house I could resist removing the baffle board and have a look and the speaker. Got the board out and removed that awful covering that was over the speaker. It looked like an old bed sheet that was spray bombed with silver paint and a liberal dose of glitter glue. Under it was the original but it badly torn and will need some sort of replacement. The speaker I think is repairable but it's missing about 1/3 of it's paper. The good news is that it's got a screwed down cone so I does come apart easily. I took a quick look around on the net to see if I could find a replacement it's a bit of an odd size. The frame close to 11" the cone needs to be about 10" or a little larger. Most of what I found was about 9 7/8. So I'm thinking a bit of construction paper and some watered down glue I should be back in business.
We would all like to see before and after pictures for inspiration. Sounds like this one is somewhere between a restoration and a crusade.
If you have had occasion to order a set of replacement surrounds for good speakers, they always include a little bottle of glue, of which you use less than half for the repair. I fixed several speakers with leftovers from last time I did my Altec 7's, and don't have any left. or I would contribute it. The stuff is somewhere between Elmers and Fabric glue. Maybe one of the vendors sells this stuff seperately. I've seen articles about everything from coffee filters to toilet paper to used dryer sheets and even pieces of old tee shirts used to fix speakers. Savages have put duct tape, wads of cotton, and worse in sets that have crossed my path. Truth be told if the voice coil is patent and you can get it to not rub, just about anything will help restore some semblence of acoustic clarity, and repairs can be made very much less apparent with a light spray of flat black enamel. Just don't go near voice coil, and yes, you can replace the little piece of felt neatly and carefully if it has one. Many screw down spiders did not, and decades of crap needs to be blown out gently or tapped out by gravity. If all else fails snf you are not looking towards starting a museum, can probably sub a modern efficient PM speaker and resistor for the field coil, if the set has one, for under $15, and it will sound better. Up to you.
Road Trip for a Philco 46-480
Good morning, folks! I’ve finished the cabinet and the electrical restoration, and have detailed those in their respecti...jrblasde — 10:56 AM
Arran, Thanks for checking you manuals. I appreciate that. Let me know what you find. PhilPdouglaski — 08:46 AM
I have some car radio service manuals, Riders I think (not to be confused with the big blue binders), so I may see if on...Arran — 01:20 AM
Philco model 40-100
Greetings; Here is an update, I found a listing on fleabay for a similar chassis to yours, and it has a photo of what...Arran — 12:58 AM
Philco model 40-100
Greetings; I think I may have found a clue as to what is missing, from a search I made, there is a rear view of the c...Arran — 12:12 AM
Philco model 40-100
I recently acquired a Philco model 40-100 farm (battery) radio. The radio was in very good condition except the red on f...mhamby — 05:59 PM
Hello, Richard the radio is an AC-2687 Studebaker model. The Philco model is S -5323 and the chassis p/n is S-5523Pdouglaski — 11:52 AM
48-482 rear panel help
The 48-482 is an AC only set as well, featuring a power transformer. While the transformer shouldn’t get “hot”, it is ye...jrblasde — 11:12 AM
I gave a Chrysler/MoPar car radio from 1954, it was made by Philco, and it uses two chassis, one has the power supply an...Arran — 11:06 AM
Hello keithchip. You could make a hardboard back for the set, but make sure you provide plenty of ventilation holes in ...GarySP — 11:04 AM
There are currently 580 online users. [Complete List]
» 2 Member(s) | 578 Guest(s)
