Ready for warm tubes to warm my heart
I have recently inherited a Philco 41-265 console radio. I am very happy to have it and would like to show it some love to get it in a working condition.
The cabinet need only one minor repair. Other than that is shows the charm from years of use (I LOVE IT!) Even has the speaker and antenna in it.
The radio is where I run into trouble. I am missing the following things:
  • All knobs
  • Buttons and button assembly
  • Needle for the dial
  • Power cable
The radio seems to have had some batteries added to it (Idonno). Also, with the needle being missing, so is the wire on the pulleys for moving it.
Where do I begin? I need some help as I have never done this before. Is there a good source for parts? Is there anyone in Southern California willing to mentor me a bit? (I'm in Palmdale)
Thanks much.
Hi and Welcome to the Phourm!
For starters if you could post some pics of the chassis it would be helpful just to see what you've got. You can post here or something like Flicker but shoot us the link.
In 1939 and thru the war years Philco used rubber covered wire along with some other manufactures. Time has probably taken it toll on it. The rubber gets brittle and flakes off. Most of the time it will need to be replaced or recovered with shrink tubing. It is a fair bit of work to do.
Then there is the paper and electrolytic capacitors. Those will require replacement. Check the resistor to see if they are ok. The knobs and buttons shouldn't be a problem I think those are being made by some folks.
If you want to dive in there are lots of good guys here to help you along the way. Sorry I can't mentor as I'm in Pa.
GL my friend
Have you removed the chassis from the cabinet as yet? You may find the missing pointer once the chassis is removed, it is also an opportunity to survey how much work will be needed. As far as I know you can buy reproduction pushbuttons and knobs for the 1941 Philco models still, and you can buy some repro dial escutcheons as well, at least for the 8 and 9 pushbutton models. If you have one with 10 pushbuttons, and it has a plastic dial escutcheon, you are out of luck unless you figure out a way to make one yourself, your set does not have this problem, the escutcheon is a wooden molding built into the cabinet. The knobs appear to be of the same style as the Bakelite ones used on most Philco models between 1936 and 1940 so fairly common, I believe the pushbuttons were Bakelite as well and fairly generic in style. The 41-265 was the console version of the model 41-245 table set according to the gallery.
Should be no batteries required on this radio. Post some pictures if you can and perhaps someone can help you find someone locally that can help you. Should be nice restored.
All the help here if you wish to do it yourself.
Jerry
New find. 91X code 225
Thanks all. To be honest I don’t know what to make of it being in this cabinet style but I like it a lot. I specifically...pdieten — 12:47 PM
Nice grab! It appears to be a 19X cabinet. This wasn't unusual. Philco often retrofitted to other cabinets as invento...GarySP — 12:32 PM
I would certainly write down step-by-step the progression of disassembly of the works, and probably cuss out the electri...GarySP — 12:18 PM
Nice looking! This annotated schematic from our library shows parts that are slightly different in the early and later ...klondike98 — 11:33 AM
LOL!! Well Arran, if you do dive into it and come across any advice on dealing with accessing components let me know. I...klondike98 — 11:56 PM
Bob and Gary; I have the further complication on the Phillips that they decided to use some 200 volt rated paper caps...Arran — 10:05 PM
Thx Arran & Gary. Yes its super crowded in the chassis and I've debated whether to try to restuff caps or not. I t...klondike98 — 07:40 PM
That's got to be one of the tightest conglomeration of components I've ever seen! I wonder how the line workers felt bu...GarySP — 05:46 PM
Bob; I think that the Phillips was actually manufactured in Canada, though they may have imported many of the compone...Arran — 02:28 PM
I've started replacing the electrolytic caps now. As Arran mentioned, they are housed under a metal strap. Here's a ph...klondike98 — 12:22 PM
There are currently 1116 online users. [Complete List]
» 1 Member(s) | 1115 Guest(s)
