Philco 111 cabinet question final pics!
City: Sedona, AZ/Placentia/CA
Hi, this is my newest Philco. The only area really bad is the underside of where the doors open. Appears to have been some scraping and the original color is off. What would you use to try to darken this area back? Of course I will also need to assure the doors don't scrape any further. Appreciate any advise.
Jerry
[Image: http://i303.photobucket.com/albums/nn129...0005-2.jpg]
(This post was last modified: 10-03-2012, 06:10 PM by jerryhawthorne.)
Threads: 112
City: Medford OR (OR what?)
Take a picture of it Jerry.
Threads: 92
City: Clayton, NC
If that's the only bad place on your set, I (personally) would not mess with it.
Threads: 18
Agree. Could put a lttle tinted bees wax. I think it would be reversible if need be.
(This post was last modified: 08-05-2012, 08:56 PM by codefox1.)
Thanks for the ideas. I like the idea of a tinted "bees wax". Would this be the same as those colored crayola type touch up crayons? This is the worse part of the cabinet. A nice water stain on the top but have that mostly minimized with a touch of stain to color and some drops of lacquer on the areas that are low due to loss of finish. A light sanding on these and a coat or two of lacquer on the top and all should come out level at least. Looks a lot better now.
Jerry
Threads: 112
Looks like Mohawk Classic Dark Walnut would be a good match if yiu want to use a toner.
Threads: 92
City: Clayton, NC
The 111 is a tough cabinet to find in decent shape, so an original in nice shape is worth preserving!
Thanks for the ideas. Will minimize any permanent changes on the finish.
Jerry
Here is a picture of the top with the water stain. The white area, what ever it was cleaned off with a little work. The hex area, well, no lacquer and down to bare wood. That I will have to contend with. Will show results when finished. I'm looking for flat and color not off too bad.
I just can't leave that like it is. Other minor blemishes fine.
Jerry
PS: It's OK to agree to disagree on this phorum.
[Image: http://i303.photobucket.com/albums/nn129...e001-2.jpg]
(This post was last modified: 08-09-2012, 04:04 PM by jerryhawthorne.)
Threads: 18
I've used artist oils with a spotting brush to fix up the inevitable flower pot rings and dings. If you have an artist aaround, it should be pretty for them to do this. Might have to make 2 or more passes to get the repair to blend in. Then let it dry for a week. Then laquer, maybe satin would be better. Two or three coats.
Threads: 92
City: Clayton, NC
In a case like that Howards finish restoration products might be just what you need.
TA, the howards may adjust the missing color but it will still leave a real dip in the finish. I want a nice flat top, true, the color should be right but the top is what you see. Especially if it had big dips in it. I will play around with it but don't want to strip and refinish. Hopefully I can get it color wise close and more importantly to me, nice and flat.
Thanks for all your ideas.
Jerry
Threads: 18
Or get a flower pot same size, you know someone will do that anyway somtime in the future.
No, codefox, my wife makes lovely covers to set on the top of my radios. She also will stitch into them the Philco logo and the make and year of the radio. Saves dusting and those question like what is it and how old is it. Just like to get it close before covering it.
Jerry
[Image: http://i303.photobucket.com/albums/nn129...300003.jpg]
Threads: 18
Jackson 665 j2 schematic request
FIXED!daveone23 — 03:55 PM |
Bakelite crack repair - what is best epoxy?
Thanks everyone. I appreciate you sharing your experience and looks like I'll work with the 24 hr two part clear epoxy....de371 — 10:25 PM |
Without a schematic its going to be hard tracing the wire wound spool resistors.daveone23 — 05:21 PM |
Looking for a schematic for the 665 j2 multimeter.daveone23 — 04:42 PM |
Looking for place to donate unique Philco Philco J-1930 Prototype
>>I'll write to the Henry Ford.
I heard, his secretary answers his mail, not he himself.morzh — 12:15 PM |
Philco 48-200 alignment questions
Just checked the power cord and I did in fact wire it so the hot side (small prong) goes to the switch.transitony — 11:52 AM |
Thanks for the suggestions. I'll write to the Henry Ford. That would certainly make sense since by the time this prod...jeibner — 11:49 AM |
For what it's worth, the Henry Ford Museum and Greenfield Village in Dearborn, Michigan may be an option.
The obvious ...GarySP — 11:39 AM |
Help with Readrite 410 tube tester
Mike and I just had a short discussion yesterday about this very subject. So often it's the connections. Ya gotta have t...RodB — 10:08 AM |
We have a regional museum here in the Twin Cities called The Pavek Museum. They have an extensive collection of communic...RodB — 09:30 AM |
