I'm in need of an arch support for a Philco 70
I'm having no luck in locating an original or a repro arch support for a Philco 70. I'm hoping someone can point me in the right direction. Thanks!!!!
I assume, sorry to use that word, your talking about the wood piece that goes around the back top of the radio. If it is missing, just find someone who has some wood working equipment and make one for you. If I misunderstood your needs, attach a picture.
Jerry
I would assume you need a replacement back piece which in this century would have made from plywood mirror sawn and glued. Not so?
Rogers Majestic R-646
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
No, you are wrong, because you did not know the details. Unfortunately, only ONE winding out of six is intact in both t...Vlad95 — 01:14 PM
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM
Thanks RodB for the help. But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM
Today I finished inspecting all the parts. The result is not very pleasing. The first positive news: 1) The power tr...Vlad95 — 11:40 PM
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM
There are currently 1032 online users. [Complete List]
» 1 Member(s) | 1031 Guest(s)
