Square tube shields
Is there a difference between the ones used in 37 (4 tabs or the base at the socket) and 39 (has the base that requires you to use a 'G' type tube?
John
Las Vegas, NV USA
No difference in the shields themselves, only in the shield bases.
1937 shield bases are the best if you need to change a base out, because they only have four flat "fingers" that hold the shield, allowing you to use any type of tube that will fit the socket - G, GT or metal. But 1936, 1938 and 1939 bases have an opening where only a "G" tube will fit. (This did not apply to 1936 models as only standard base tubes were used in the 1936 Philcos, not octals.)
hello mr Fixr, for sure !! I have some radios that I need to make some batteries for too. Sincerely richardradiorich — 12:33 AM
Dittos, sweet b on the battery. Love the "9 Lives" logo, remembered from my childhood. Other neat ones are t...MrFixr55 — 11:24 PM
Hi Morzh, Dunno if the AC EMI caps are an issue. I never liked the concept but never had an issue with these causin...MrFixr55 — 11:21 PM
And no hum without the 7AF7? Not common but I am thinking heater - cathode short. This would introduce hum in this sta...MrFixr55 — 11:14 PM
schematics
Those filter caps in the cardboard tube are easy to restuff, especially the kind with the rolled over end. You don't hav...Arran — 09:56 PM
If you have 5 wires, do this: The wires that go to thick-wire wound winding are the filament. If you do not know wha...morzh — 09:03 PM
I recently acquired a Philco Model 16 Code 126. I removed the power transformer to place heat shrink on some very bad...bobclausen — 08:23 PM
Hello Bob, That battery looks great nice job ! Sincerely Richardradiorich — 08:20 PM
Yes, I plan to put a Velcro closer on the top.klondike98 — 07:28 PM
Nice job on the battery, Bob. Can the box be opened to replace the 9 volters?RodB — 11:32 AM
There are currently 655 online users. [Complete List]
» 1 Member(s) | 654 Guest(s)
