Threads: 55
City: Claremont, NH
I saw a large Philco shouldered tombstone in a shop recently. It is a multiband radio with hexagonal knobs, 8 tubes and big honkin upright transformer on the left side as you are looking at the back. I could see no model ID on the chassis or on the bottom of the case. $60. If I remember correctly it had four bands. I probably should have grabbed it.
After looking for a week I can't determine exactly what I was looking at. Your thoughts please. Thanks.
OK, Now I understand why "eyewitnesses" don't always have the correct info when an accident or crime occurs.
The set is I believe a 97B, 7tubes, three bands and I already screwed it up.
I have damaged the dial. I have read about not cleaning these and I thought the lettering was on the back of the dial, not the front. I use Q-tips a lot to clean radios. I did the dial and got a lot of what I figure is tobacco smaoke off. It was fine and I should have left it, but did one more pass and took part of the lettering off. It is still usable but with one bad area. Have already checked and no repros for this dial. Color me stupid.
Here are some pics.
[Image:
http://i1185.photobucket.com/albums/z345...er/97b.jpg ]
[Image:
http://i1185.photobucket.com/albums/z345...r/97b1.jpg ]
[Image:
http://i1185.photobucket.com/albums/z345...r/97b8.jpg ]
[Image:
http://i1185.photobucket.com/albums/z345...r/97b6.jpg ]
[Image:
http://i1185.photobucket.com/albums/z345...r/97b9.jpg ]
[Image:
http://i1185.photobucket.com/albums/z345.../97b10.jpg ]
[Image:
http://i1185.photobucket.com/albums/z345...r/97b5.jpg ]
[Image:
http://i1185.photobucket.com/albums/z345...r/97b3.jpg ]
[Image:
http://i1185.photobucket.com/albums/z345...r/97b4.jpg ]
[Image:
http://i1185.photobucket.com/albums/z345...r/97b2.jpg ]
Gene
(This post was last modified: 10-02-2012, 07:06 PM by
Gene Pederson .)
Threads: 17
City: Yorkville IL
Almost sounds like a 118B. Did it have a shadow meter?
Glenn
Happily back in Illinois..not.
Threads: 55
City: Claremont, NH
Hi Glenn,
I believe it did. It was just above the tuning gang. A small rectangular piece.
Gene
Threads: 17
City: Yorkville IL
Look like this? This was my 118H, but it's the same chassis. This was pre-restore. I forgot to get a picture once it was cleaned up.
Glenn
Image(s)
(This post was last modified: 10-01-2012, 11:25 AM by
Glenn Roberts .)
Threads: 55
City: Claremont, NH
I think that looks correct. Was $60 a good buy? How do these sets perform?
Gene
Threads: 17
City: Yorkville IL
They are great players! P/P. 42's., 3 gang tuner. I have a 118B in the stack. The problem seems to be when the shadow meter goes bad it stops playing unless a resistor is in place to keep the circuit active. I had 2 chassis and neither one had the resistor. Ron sent a picture to me to show the proper location.
To answer your question, that is a great price especially if the cabinet is in decent shape.
Glenn
(This post was last modified: 10-01-2012, 11:55 AM by
Glenn Roberts .)
Threads: 55
City: Claremont, NH
Thank You for all the info and help Glenn! I will check to see if it is still there.
Gene
Threads: 92
City: Clayton, NC
Hello Gene/Glenn: if it had four bands, eight tubes, and is in a shouldered cabinet it probably had an oval dial and is a model 650.
The 650 is an excellent set!!
DEFINITELY worth 60.00
(This post was last modified: 10-01-2012, 12:10 PM by
TA Forbes .)
Threads: 55
City: Claremont, NH
Hi TA! And Glenn, I just called and it is still there so they are holding it for me to pick up tomorrow. And the price is $60. So whichever model it is should be good
The only pita I can see is there about 10 of the bakelite block caps in these, right?
Gene
(This post was last modified: 10-01-2012, 12:37 PM by
Gene Pederson .)
Threads: 17
City: Yorkville IL
Please post some pictures when you get it home
Glenn
Threads: 72
City: Linn Creek, MO
It would not be a 118 if it has four bands. It might possibly be a 640 or a 650, I'm not that familiar with the 6xx Philcos. At any rate, you better get back there and grab it before someone else does.
M R Radios C M Tubes
Threads: 72
Oops, I see TA already said that.
Threads: 55
City: Claremont, NH
Well Steve, and everyone I wasn't even close on the description.
See my edit and pics.
Gene
Threads: 72
Congratulations Gene, that was an excellent buy!
Threads: 92
City: Clayton, NC
Yes indeed, an excellent buy!!! The 97 is a three band , seven tube set, so you fooled us!
The 97 is a rare set. Note the production numbers in this site!
I have one, and it is a good set. Do a good electronic resto on yours and your set will pleasantly surprise you.
Does your 97 have a dial that is almost red in color?
Hi Paulo,
Welcome to the Philco Phorum.
I can see why you want to find good reproduction parts. That is a bea...MrFixr55 — 11:10 PM
Tim,
I have some bakelite sockets in my work shop that I can dig up. I believe quite a few are NOS. I will take photo...RodB — 10:03 PM
Tim;
I noticed your post a little late, but I would take one of the junk sockets and try to break a chunk out of it wi...Arran — 08:07 PM
First Radio restoration
Hi Tubeman,
Welcome to the Philco Phorum. Phamily Phriendly Pfun with Phine Pholks Phull of Philco Phacts. (See a p...MrFixr55 — 12:33 PM
Good ideas, thank you Arrange and Rich. I have the adhesive aluminum foil already and can try that immediately.
More ...EdHolland — 10:18 AM
Murf;
I found this thread on the ARF, the first photo has a pretty good view of the dial glass.
ArranArran — 01:12 AM
hello Ed,
how about that speacial tape used for ducting it's like foil or how about thin piece of
aluminum roof flash...radiorich — 12:19 AM
There are currently 1416 online users. [Complete List ]» 1 Member(s) | 1415 Guest(s)
