Philco 118B veneer type
Does anyone know what wood species the 118B used? I am trying to restore a bad cabinet and have to replace the veneer in the center of the radio.
http://www.philcoradio.com/gallery/1935a.htm#e
I think it's stump or crotch walnut, if you mean the portion where the dial escutcheon is. The pieces on either side of that center portion is maple or beech veneer with a dark lacquer over it.
Hi Aaran,
It is the center piece where the esscutcheon is that I am referring to. It was patched over so many times I decided to replace it as it was in a lot of pieces. I am not sure where to get that veneer type.
Ill see if I can find a supplier.
Stump walnut is somewhat hard to find these days but it is out there, Bob Andersen found a supplier of stump for his Philco 115DX's cabinet, not large pieces mind you. Perhaps you should contact him and ask where he got it from? If that fails sometimes you can find sections of burl walnut that look close enough to work.
I had someone at a local Woodcraft store help me with identifying it. They had curly walnut that looked a good match. I am going to try that and if it doesn't look right I can always try again.
Thanks for your advice.
I've heard of woodcraft stores, they seem to be sponsors of a few how to shows on PBS, they sound like a useful outfit. In any event curly grain is what you need regardless of what part of the walnut tree it came from, it may have been a stump or crotch cut of French walnut originally but as long as the colour and grain of the replacement veneer is close it will work.
arran
Hi SQ55, A strange issue indeed!  Just so I have you straight, on a dim bulb you get normal operation after the set war...MrFixr55 — 12:44 AM
schematics
I think mseno is talking about cap# 27 which is a multisection but in a paper tube. In cases like that I've usually be ...klondike98 — 11:25 PM
schematics
Ohrenet  :roll: For their price I would chase a fly in a field.  :twisted:Vlad95 — 11:21 PM
A bit more work on the Motorola. I got the repro battery together right up until I realized the snap clips on the top o...klondike98 — 10:45 PM
schematics
Often restuffed. If a twistlock, Hayseed Hamfest makes modern replacements. morzh — 09:18 PM
schematics
Looking for a multi-sectional 8+16 mfd cap. Can't find any suppliers that carry it.mseno — 08:45 PM
schematics
Richard, thanks so much, greatly appreciatedmseno — 08:39 PM
I'm starting to restore a Philco 16X, I need spare parts. Please, help me find ...
Peter; I believe that the "A" suffix means that it has as 25 cycle power transformer, not all Canadian sets...Arran — 07:05 PM
I am back tracking on my resistors as the one that burned based on the old one's resistance was correct but another resi...osanders0311 — 05:34 PM
"So you can see how Important it is to identify parts with the schematic, especially when you have multiple parts o...osanders0311 — 05:23 PM
