  • 1 Vote(s) - 5 Average
16B cabinet
Hi Ron and all
Is this the correct toning of the 16B cabinet? I have my cabinet ready to spray (sides and top only) and need to ask if this is the correct toneing. Icon_confused
Joe
[Image: http://i927.photobucket.com/albums/ad118...co16B3.jpg]
Joe, It looks very good to meIcon_thumbup
M R Radios   C M Tubes
Thanks Steve Icon_wave
Joe
I did some searching on the web and this is the best photo I found of one with the original finish.
http://www.tuberadioland.com/philco16_ca..._main.html
The 16B which Bob linked to is a perfect example of another controversial subject - were the edges and trim toned dark, or not?
Like the top edge of the 620/623B front panel, some were, some weren't. No rhyme or reason.
Thanks guys. Ron which of the decals is correct for the 16B? From radio Daze. Joe
You want DCL-PH8 - and remember, they are now authentic Icon_smile
Looks downright Snazzy now.
Wr4rtc,That is a beautiful set!!
I can feel the 16's slowly sucking me into having to have one.........they are extremely impressive radios!
Gene
Rogers Majestic R-646
Vlad; I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM
Thanks RpdB I don't think there's much difference with interstage transformers of different models other than dimersion...Vlad95 — 03:27 PM
Vlad; I looks like your set has the same problem that mine did, both a bad output transformer, and a bad audio inters...Arran — 03:21 PM
Ouch! Not often the secondary takes a hit. Wish there was a better solution. I have a good interstage transformer but it...RodB — 02:59 PM
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
No, you are wrong, because you did not know the details. Unfortunately, only ONE winding out of six is intact in both t...Vlad95 — 01:14 PM
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM
Thanks RodB for the help. But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM
There are currently 1101 online users. [Complete List]
» 4 Member(s) | 1097 Guest(s)
AvatarAvatarAvatarAvatar
