philco 37-650 dial window and surround
trying to remove dial window and surround complete from 37-650 anyone removed this. i dont see anything but two tabs on the back and straightening them didnt help-------------- thanks
Turn the outer ring counter-clock wise and it will come apart. Be careful as the glass will fall out when you do this.
thanks. i will watch the glass
I'm going to try this on a 38-10F. It sounds like it's of simular construction. Thanks.
Yes, same thing. Good luck!
Shadow Meter Bulb
Model 28L
37-60 revision 6
Shadow Meter Bulb
Hickok AC51 tube tester
Model 28L
Hello, I'm restoring a Philco 28L and the output transformer is open. Part number of the transformer is 32-7020. Can...HORSTE — 10:32 AM
Philco 42-1008 conversion kit
I read about a kit to convert the variable speed changer in the Philco 42-1008 into a single speed unit.  That would rem...alangard — 09:30 PM
Tim Well...a chassis is metal. Magnetic or not, it does not matter. A transformer has some hum to it. It is natural. Th...morzh — 08:40 PM
I thought the 83 tube was bad because it looked white but it tests strong. Blue gassy though. I checked the fuse, it was...martinj — 08:37 PM
Shadow Meter Bulb
Ross I am not sure what current limiting effect the incandescent provides. They are two different parts of the sch...morzh — 08:31 PM
There are currently 6152 online users. [Complete List]
» 1 Member(s) | 6151 Guest(s)
