38-17 wood type and finish
I have stripped the old finish off a Philco 38-17. The top which roles over to the front has three vertical bands of wood which appear to be the same kind of wood, but the middle band is lighter in color. There is also a horizontal strip across the front bottom. The sides of the radio appear to be a differnt kind of wood with not a lot of obvious grain. Can you tell me what kind of wood(s) I have? Should I use a wood filler and if so what color(s)? After using a filler and sealing what color stain(s) should I use? I'd like to create something close to the original color and finsh as possible. Thanks.
Hi,
The radio uses walnut veneer in all but the edges; these are surely "white" wood (cheap, without much grain). I recently acquired a 38-17 myself and, while looking it over before responding to you, I noted that the entire cabinet appears to have been done in medium walnut toning lacquer. There is more toner on the edges as they are just a slight bit darker; this is not surprising, given the cheap wood used on the edges, it would have been desirable to hide this fact as much as possible.
Some refinishers use wood filler in a color similar to the final finish to fill in the pores; others use multiple coats of lacquer, sanding between every so many coats, to achieve the same effect; i.e. a smooth, piano-type finish.
As mentioned above, the original finish was tinted lacquer. This will be much easier to use - and control the final color of the finish - than using stains.
Hello Bob, That battery looks great nice job ! Sincerely Richardradiorich — 08:20 PM
Yes, I plan to put a Velcro closer on the top.klondike98 — 07:28 PM
Nice job on the battery, Bob. Can the box be opened to replace the 9 volters?RodB — 11:32 AM
Thank you for the detailed response MrFixr. To clarify, the hum starts when the tubes are fully warmed up, and goes a...sq65 — 09:15 AM
MrFixr The chassis, if there is no ground pin in the AC plug, due to the Y-caps from L/N to the chassis, is at 60VAC re...morzh — 08:47 AM
schematics
thanks I'll try the polar caps seperatelymseno — 07:38 AM
Hi SQ55, A strange issue indeed!  Just so I have you straight, on a dim bulb you get normal operation after the set warm...MrFixr55 — 12:44 AM
schematics
I think mseno is talking about cap# 27 which is a multisection but in a paper tube. In cases like that I've usually be ...klondike98 — 11:25 PM
schematics
Ohrenet  :roll: For their price I would chase a fly in a field.  :twisted:Vlad95 — 11:21 PM
A bit more work on the Motorola. I got the repro battery together right up until I realized the snap clips on the top o...klondike98 — 10:45 PM
There are currently 1184 online users. [Complete List]
» 2 Member(s) | 1182 Guest(s)
