Philco 15X Back panel and labels?
Threads: 9
City: Rockwall,Tx 75087
State, Province, Country: TX
1) Does anyone have a source method to reproduce the label set for this model? I tried a source on eBay but he does not cover this model?
2) Back cover board: Does anyone know of a fiberboard material similar to the original black material used for the back panel cover. It was covered in black felt and perforated with multiple 1-2 inch baffle holes?
Threads: 92
City: Clayton, NC
Wow, that's a new one for me, but would NOT be suprised if someone made one!
The material is much like the "matting" used by custom framers, and you can buy it by the sheet at Michaels craft store (or, at least, they used to sell it).
I bought a large sheet of the stuff some years ago to make backing boards for grille cloth in cathedral and tombstone radios, and still have about half of the sheet left.
Of course, then you would have to deal with making the round holes for the authentic look.
As for the label, I might be able to come up with a scan, but I cannot do so right away - it will take some time as I'm frankly quite busy at present.
Threads: 51
The closest thing I have seen to the cardboard used in radio backs was the thick cardboard they use to make car door panels with, which you can still buy from an upholstery supply, someone told me it was called "Waterboard" but they may or may not use that term.
Threads: 20
City: Oskaloosa
State, Province, Country: KANSAS
Untill I found this post while searching I did not know the 15X even had a back. I would like to try recreating the back for my 15x. Can anyone give me an idea of total numbers of holes, or a better picture? A scan or a high resolution scan of the back label would be helpful to.
Any other suggestion would be appreciated.
Thanks
Skip
Threads: 9
[attachment=1347][attachment=1345][attachment=1346]Skip: I reproduced mine with double poster board from Michaels Hobby Shop, and covered with black felt per the original. Used as hole saw to punch the board. Also "fake" reproduced the back label. I posted the jpg on the downloadable files for a converted 111 label to a 15 model. Its not = to the original verbatim, but it has very similar look. Color printed on a single label sheet 4x. Ill try to attach photos of final back look.
Threads: 20
City: Oskaloosa
Radioguy52
Did you make the tube shield or is that original. Mine is missing and I was planning on using individual tube shields I have laying around untill I either found one or made one.
Thanks for the pictures and idea. I was thinking along the same lines as what you did. Your 15X looks very nice.
I noticed on your radio you have decals for each knob, I have not seen a 15X with any other decals then the Philco, are those correct? If so did you get them from Radiodaze?
Thanks
(This post was last modified: 11-30-2012, 09:25 PM by Skip.)
Threads: 9
skip. I was lucky and the tube shield came original. decals.. You are correct original did not have the volume tone on off But I was restoring for someone that I thought would find it useful to know which knobs do what since tone and volume look same..So I took a little librerty from original. decals came from Radiodaze.. The jpg is loaded in the phorum archives... This was a fun project...
Threads: 147
City: Dallas, TX
I used a pressed fiber board from home depot,forgot the name of the stuff,the thickness was just right,very durable,used a holesaw for all the holes,sanded smooth all edges. use your old cover for templet ,your lucky. i had to do mine from a picture ,took a while to get holes in the right place. then i spray painted it to match factory color from picture i used. then i used a black or brown if you like, window screen attached to inside of of your board , this worked very well ,looked factory this was done for my philco 23x that i restored over the summer and won first place,peoples choice award, and best of show, How about that. i sure did that old 23x proud as Tom Forbes had said. Merry Christmas to all from Fred and BIG Henry from DALLAS tx
Threads: 147
City: Dallas, TX
Hi this is FRED again i will post pictures of 23x and the back cover as soon as i can figure out how to do so.
Shadow Meter Bulb
Now if you had a set with a tuning light then the bulb type is important to the circuit, some sets used those prior to t...Arran — 04:58 PM |
Shadow Meter Bulb
Ok. Thanks for the correction.RossH — 03:09 PM |
Model 28L
For 28 you will probably need to buy a Hammond 125CSE. Or any of the series of the power you need, with SE suffix. Then ...morzh — 02:09 PM |
37-60 revision 6
I am restoring a Philco 37-60 and it shows run 6 they removed the ground from G3 of the 6K7G and put the G3 to -2.5v for...bobbyd1200 — 01:01 PM |
Shadow Meter Bulb
Mike is correct on the bulb connection, two separate circuits. I found that by rotating the bulb and sliding it forward ...RodB — 12:19 PM |
Hickok AC51 tube tester
Cleaned ann contacts, switches and sockets, works great now.martinj — 11:32 AM |
Model 28L
Hello,
I'm restoring a Philco 28L and the output transformer is open. Part number of the transformer is 32-7020.
Can...HORSTE — 10:32 AM |
Philco 42-1008 conversion kit
I read about a kit to convert the variable speed changer in the Philco 42-1008 into a single speed unit. That would rem...alangard — 09:30 PM |
Tim
Well...a chassis is metal. Magnetic or not, it does not matter.
A transformer has some hum to it. It is natural. Th...morzh — 08:40 PM |
I thought the 83 tube was bad because it looked white but it tests strong. Blue gassy though. I checked the fuse, it was...martinj — 08:37 PM |
