Philco 84, paint or stain?
I am into the cabinet restoration of my Philco 84. It seems there are 3 differrent tones/stains on this canibet. It is currently stripped down. The trim and grooves (face) almost seem to be done in black paint? Does anyone know if this should be an ebony stain, or some kind of a paint? I keep reading about some "Mohawk" stuff, but I haven't seen this brand in any of the stores. Also, any wood filler recomendations?
Some of the more experienced folks will be better able to advise on the use of these but Ron had a post that had some suppliers, see: http://philcoradio.com/phorum/showthread...ght=mohawk and Antique Electronic Supply carries some as well. Mohawk's web site also has a search feature to show distributors near your zip code.
Bob
Ok thanks, I guess I just needed to read a few threads to point the way. It appears using stain is "bad juju". Constantine paste wood filler seems recommended for the porous grain. Then, Mohawk Perfect Brown over all, Extra Dark Walnut, built up on edges and trim. But can anyone suggest the color for the lighter toned inner face of the model 84?
There are a lot of specialty products that cannot reasonable be shelk stocked in low to medium volume brick and mortar stores because of of inventory and shelf life reasons. Best get them from the net, or get a localdealer to special order for you. Might or might not come out ahead by doing so.
Toning Lacqers is what to use. Mohawk brand is good.
Happy New Year,
Chuck
Thanks Chuck, I'm ordering the toner. By the way, thanks for the schematics and info on the 40-180. My first restoration turned out great (by newbie standards anyway). Now the relatives want one! Oie! if they only new the time and effort involved!
Shadow Meter Bulb
Shadow Meter Bulb
Model 28L
37-60 revision 6
Shadow Meter Bulb
Hickok AC51 tube tester
Model 28L
Hello, I'm restoring a Philco 28L and the output transformer is open. Part number of the transformer is 32-7020. Can...HORSTE — 10:32 AM
Philco 42-1008 conversion kit
I read about a kit to convert the variable speed changer in the Philco 42-1008 into a single speed unit.  That would rem...alangard — 09:30 PM
Tim Well...a chassis is metal. Magnetic or not, it does not matter. A transformer has some hum to it. It is natural. Th...morzh — 08:40 PM
I thought the 83 tube was bad because it looked white but it tests strong. Blue gassy though. I checked the fuse, it was...martinj — 08:37 PM
