Philco-18 problem
When I bought this radio from a radio person, he explained away the following note as "probably caps": 80 tube overheats, do not energize until problem is found. So I took out the 80, and did some voltage checks. The voltages to the 80 were right on. Filaments to the other tubes OK. Field coil OK, choke OK. So I stick the 80 in and at around 80 volts, there are little sparks on the 80 tube socket (from underneath) and I quickly shut down. The 80ST shows shorts and no filaments.. I hadn't checked it before this. Now, before I start the lengthy (but enjoyable Icon_wink ) recap, do my initial transformer checks rule out a transformer problem? Anything else to check first? Suspects?
What schematic do I want to be looking at? This chassis has a band switch; the on/off is with the volume. The electrolytics don't match up with 18 schematic. For example, I don't have part #s 59 & 60 (8uF & 10uF and 8uF), I have a 20/20/20 can.
Bad 80 tube socket? This has been known to happen in Philcos of this vintage.
If it has two bands (AM and the "police" band), on-off with the volume control, then it is the early 18 - not the later Code 124 (AM only) version.
Quote:then it is the early 18
Is this something that I have to get from The Philco Repair Bench?
Ah, I see what you mean - the early 18 isn't at Nostalgia Air.
Well, if you want good, clear, readable schematics with all production change notes, etc., then - yes.
Well worth the 7.00 from Chuck.
Quote:Bad 80 tube socket? This has been known to happen in Philcos of this vintage.
Electrolytics this time.
Quote:Well worth the 7.00 from Chuck.
Check went in the mail today.
Okay, just trying to help...good luck...you may need it.
Quote:Okay, just trying to help...good luck...you may need it.
I love your help! Now, why may I need good luck??????
If you saw sparks in or under that socket and it is a wafer style, then you better keep an eye on it after you are done. Any arc will burn a trace between the layers of the wafer resulting in a HV short that just gets worse.
And that was the point I was trying to make, DK! Phlogiston is 100% correct.
Now, let's all go put some extra Chivas Regal in our New Year's drink for this evening and have a nice night.
I still have a transformer to wind. Will Chivas Regal help - you know it will!
At long last, it is aligned! I’ve uploaded a couple of new videos to YouTube to demonstrate. YouTube picked up on Hall a...jrblasde — 10:08 PM
Hello Phil, Welcome aboard what is the model number of that radio ? Sincerely Richardradiorich — 10:06 PM
Just speculating of course, but you could probably find another transformer from another car radio of the same era, pref...Arran — 09:00 PM
Hello I am new here and I could use some advice. I am working on my 1955 Stude/Philco car radio and have determined tha...Pdouglaski — 06:43 PM
Thank you MrFix55 and GarySP with helping with the Antenna, for now I am placing the Antenna on the back burner and work...osanders0311 — 02:24 PM
There are currently 2005 online users. [Complete List]
» 3 Member(s) | 2002 Guest(s)
