what type is this?
My grandmother asked me to try to figure out what type of radio this is. Any help would be fantastic!
A mid to late 1960s cabinet stereo, I can't tell you the brand off hand, they all pretty much look alike. In any event they don't tend to have much, if any value, at least the solid state ones, if it were a tube type Fisher it would be worth more, but still nothing outstanding. In this case it's in decent shape so someone may want it for a phonograph, or for a liquor cabinet conversion.
Often those huge 1960's to 1970's have a negative value; an owner will sometimes need to pay someone to take it away.
Pete AI2V
Thanks!
On the other hand if they work or you can stuff them with whatever and you have plenty of room, they can double as a greenhouse or sun room plant table. Agreed, virtually worthless otherwise.
If it uses a tube amplifier, the amp likely has some value to people over at audiokarma tube forum.
I would not be so negative. Any value to collectors? Absolutely none. Any value to you due to your relationship to it, you decide. Keep it if it has value to you. Sound wise, probably blows away any of the stuff most of us collect. I realize you were not particularly asking about value but model number/brand. To answer those questions, we would need some close up pictures of the control section and some looking at the back of the cabinet for that type of information.
Jerry
Rogers Majestic R-646
Thanks RpdB I don't think there's much difference with interstage transformers of different models other than dimersion...Vlad95 — 03:27 PM
Vlad; I looks like your set has the same problem that mine did, both a bad output transformer, and a bad audio inters...Arran — 03:21 PM
Ouch! Not often the secondary takes a hit. Wish there was a better solution. I have a good interstage transformer but it...RodB — 02:59 PM
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
No, you are wrong, because you did not know the details. Unfortunately, only ONE winding out of six is intact in both t...Vlad95 — 01:14 PM
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM
Thanks RodB for the help. But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM
There are currently 1016 online users. [Complete List]
» 1 Member(s) | 1015 Guest(s)
