Power transformer question
I'm working on an 84, and this thing is a mess. Whoever had it before tried to fix it up and did a horrible job. Anyway, The schematic shows that the transformer lines that go to the tube heaters has a center tap that connects to a resistor and cap by the 42 tube, as well as to another winding on the transformer. On the leads going to the heaters, I don't have a center tap wire.
It's part number 32-7180. Any ideas on this?
The center tap was eliminated on 2-1-1934, from then on one side of the filament line is grounded.
This change, and many others, are in the must-have Philco Changes in Models PDF that may be found here:
http://www.philcoradio.com/phorum/showth...hp?tid=215
Thank you very much. Lot's of useful info there.
Just an aside, it makes very little difference in most sets if the replacement transformer does not have a center tap for the 6.3 volt winding, just so long as one or the other returns to B- or ground. True mostly on larger amplifiers as well. There are several schemes use to fein a neutral ground to minimize hum including resistors and potentiometers wired from both poles of filament winding to "ground." Nine different ways of Sunday.
Philco 89 Code 123 Osc Coil
There are currently 1395 online users. [Complete List]
» 1 Member(s) | 1394 Guest(s)
