dial lamps sockets and repair
I'm fairly certain I have seen a thread or something in Chuck's forum on how to properly rebuild dial light sockets. Could be my aging brain but I can't seem to find it. Need the hints on the rubber in the socket and what to use. Mine on a 38-116 have just fallen apart. No connection to the bulb with nice power to them. No shorts yet! A little help please?
Jerry
http://www.philcoradio.com/tech/lamps.htm
TA, that was exactly what I was looking for thanks so much. Now if anyone out there has a parts chassis for a 38-116, I need a couple parts. See the wanted add on the forum. I can remember when I see stuff of interest but often times when I need the info I forget where it was at.
Another trick may be to find a flat faucet washer of about the same size to use as an insulator, those are made out of a hard black rubber (likely synthetic) so they would look like they belong in there.
Rogers Majestic R-646
Thanks RpdB I don't think there's much difference with interstage transformers of different models other than dimersion...Vlad95 — 03:27 PM
Vlad; I looks like your set has the same problem that mine did, both a bad output transformer, and a bad audio inters...Arran — 03:21 PM
Ouch! Not often the secondary takes a hit. Wish there was a better solution. I have a good interstage transformer but it...RodB — 02:59 PM
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
No, you are wrong, because you did not know the details. Unfortunately, only ONE winding out of six is intact in both t...Vlad95 — 01:14 PM
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM
Thanks RodB for the help. But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM
