Philco M3850T
I hsve a Philco M3850T with no FM reception. Am works OK. No Sams information available. Does anyone have a source for origional Philco service or parts list for this unit? This unit is a little new for this forum but thought would give it a try. Thanks for any help.
Martin
Martin,
Sams does cover an M3850TWA in 1149-5.
Might be the same receiver with phono.
Carl
Northern Panhandle, WV
Carl
Thanks for your response. I found the Sams and the FM limiter was bad. Found an ECG 703 to repair it. Thanks again.
Martin
[split] New member...
I think my thinking is upside down but just flipping it raises another question. I think the gap that I was adjusting w...HowardWoodard — 01:07 PM
Philco 37-116 Cabinet Repair
In cases I've had like this i just clean the cracks out and get them close to the veneer color. (Stain or dye to darken...poulsbobill — 12:18 PM
That was my thinking on why the splits. I had to remove some old badly damaged (water) from a cathedral (91) with booken...dconant — 10:50 AM
Yep, there is no question that the wood filler stains a different color than the surrounding wood. You can try toning l...klondike98 — 10:50 AM
Help with Supreme 599
Now I understand. Your schematic has been altered. The original is on Steve Johnson's site at: 599, 599-C Schematic N...DaleHCook — 10:49 AM
The way it is cracked, all up and down the corner, suggests the veneer has been in a dry environment for a very long tim...RodB — 10:37 AM
The wood filler idea does not work worth a crap when it comes to staining. I filled in a few spots on another radio and ...dconant — 10:31 AM
First, there are folks more skilled than I am that may have other opinions but for what it’s worth… Repair of cracked...klondike98 — 10:19 AM
Philco 38-10 Tuning Condenser
Hello, Working on a 38-10 where the tuning cap gears have separated. I have got one spring out that was jamming the a...dconant — 09:56 AM
I get that part of it. I moved the switch to the line adj position on the schematic. As you can see it goes no where.daveone23 — 09:34 AM
There are currently 981 online users. [Complete List]
» 3 Member(s) | 978 Guest(s)
