Starting a 66B
Now that I have my 41-220 working I am going to start a rebuild on a 66B tombstone and was curious if there were any pitfalls to watch out for? A good start is that the IFs and coils check good. Bad thing is the choke shows open. Also, the speaker cone is pretty well tore up so will need a new cone for it.
Jim,
Just finished two 66s- one of which is a B. Both had good coils and good speakers. Simply had to re cap and replace resistors. They both had frozen bandswitch switches. Simply heat the shaft with soldering iron and use something like WD-40 and eventually they will free up. One of the switches had actually broken so I had to remove a fix. Other than having to correct someones previous attempts at repair, they both came out great. The guys on this site are super! Nothing they can't help with.
Good luck,
Joe
Thanks Joe. I just ordered the parts I'm out of for this radio last night. I'll probably start with the raised board section. There are a few resistors on the board that are way OOT and was thinking about just cutting their leads and tacking them in place on top of the board and mounting the replacements underneath. I'll still need to find a replacement choke unless I get lucky and there is only a break under the outer wrapping.
Following some google threads on the choke I was able to pull it apart and find the break. Resistance now reads about 2060 ohms so if all goes well with putting back together
I think I'll have a winner.
1 question I forgot. Now that I have found the break what do I use as far as an insulating paper? I still have the very outer section but do I use for the inner section? Seems like it was some kind of mixture between wax and a fiber(?) tape.
HMMM, looking at the resistors on the raised board the are some decrepencies. Example is #43 which the schematic says is a .1MEG and the parts list also says its a .1MEG but the color code stated is WHITE-WHITE-ORANGE which is a 90K and thats what is physically on the board. Guess Philco wasn't very good at quality control when it came to publishing their schematics.
WHITE-WHITE-ORANGE would be 99K, that's pretty close to .1 meg. I have seen this in several Philcos.
M R Radios   C M Tubes
Yep, Philco often used 99K resistors where the schematic called for 100K. The 1000 ohm discrepancy didn't matter, it was well within the 20% (or more) tolerance of those old resistors.
Same on mine with the resistors. I replaced resistors with what the schematic called for. worked great.
Joe
[split] New member...
Well, with the replacement tuning assembly, I have finally put the unit back together and aligned the dial.  The first s...HowardWoodard — 01:01 AM
Well, finding a short is easy. Like I said, disconnect the transformer's secondary windings and see if it persists. If...morzh — 09:48 PM
Restoring Philco 96
Nice one!Stan the Man — 09:37 PM
Restoring Philco 96
I have eventually replaced the speaker and shot the video, which only shows the upper part of the dial as the hum is ver...morzh — 09:24 PM
Rogers Majestic R-646
Kinda weird to see both open Nothing weird if you remember that this radio is about 100 years old  :)Vlad95 — 07:49 PM
I believe I'm making progress, resistors have been rechecked and corrected, removed that ugly blue capacitor and more wi...osanders0311 — 07:38 PM
Thanks Morzh Yes I recapped everything and replaced almost all the resistors as well. I redid #99 with .015 safety ca...bobclausen — 07:11 PM
Well...pull out every single load of the transformer. For every winding. Unsolder if needed. Then re-do your dim bulb....morzh — 07:02 PM
Kinda weird to see both open, but once you get it up and running, really pay attention to your sound. Listen for loud cr...TV MAN — 06:59 PM
Vlad; I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM
There are currently 1120 online users. [Complete List]
» 2 Member(s) | 1118 Guest(s)
