Philco Model 610
I'm looking at a model 610 for less than $100. The cabinet looks good and it will have to be restored to get it to work.Does this sound like a good deal? What can you guys tell me about this set?
Eric
Eric
The Villages, FL
It's a five-tube, three band set. For what it is, it gets good reception on all bands with a good antenna.
Thanks, TA I'm going to go for it.
Eric
Eric
The Villages, FL
Offer them as little as possible for it, I wouldn't pay a full $100 for any five tube set needing refinishing and does not play, they were a good entry level AC set but like most 5 tube sets they are not hard to find.
One thing this 610B has going for it is that it appears to have the original toning, or else someone refinished it and tried to get the original two-color toning right (hard to really tell from the thumbnail). I have seen so many 610B sets that have been stripped and refinished in a single color...it's nice to see a proper looking two-toned 610B for a change.
The 610 is nice entry level set easy to work on and will give good performance. I like them! Price is a bit stiff.
The price kept going up so I passed on it. Maybe the next one.
Eric
The Villages, FL
What do you mean that the price kept going up? Was this a private sale you were working on or some auction? If you want a Philco tombstone set from around this period see if you can get a 620, 630, 640, or even a 650, or a 116. Generally speaking the average guy doesn't know the difference between a 5 tube set like a 610 and a 6, 7, 8, 9, 10 or 11 tube set so superior performance doesn't necessarily equal a superior price.
It was on ebay. Thanks for the information. I now have a better idea of what to look for.
Eric
Eric
The Villages, FL
Rogers Majestic R-646
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
No, you are wrong, because you did not know the details. Unfortunately, only ONE winding out of six is intact in both t...Vlad95 — 01:14 PM
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM
Thanks RodB for the help. But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM
Today I finished inspecting all the parts. The result is not very pleasing. The first positive news: 1) The power tr...Vlad95 — 11:40 PM
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM
There are currently 1040 online users. [Complete List]
» 2 Member(s) | 1038 Guest(s)
