I picked up an ivory Hipppo that someone thought would look good painted with white latex paint. I'm working on that issue but my problem is the knobs. I'm not having a good time getting the paint off of them. Does anyone know where I might get some replacement knobs? They are the normal Bakelight color.
Eric
Eric
The Villages, FL
Try using dot 3 brake fluid to get the paint off the knobs, people have used that to get paint off of polystyrene and lucite with no ill effects. In all honesty soaking them in water may get the latex paint off. I think the knobs on these were made out of Tenite II, the improved version of Tenite that does not warp, shrink, and disintegrate. They are very similar to the knobs used on a 46-1201 and several other sets. I have two so called "Hippo" sets, one is white and has a tuned RF amplifier stage, the other is brown Bakelite and has a 14AF7 mixer-oscillator and an extra IF amplifier stage. They are decent sets but people often make the mistake of paying too much for them thinking that they must be rare, which they are not.
Thanks Arran, I'll give it a try.
Eric
Eric
The Villages, FL
Thanks Arran. The brake fluid worked great! After some polishing the knobs look like new.
Eric
Eric
The Villages, FL
I have a Hippo, pretty good little set. In Boston I get all the NY City Stations at nite and many low power locals. They are nice and small so they can follow you around the house. I think some collect them because of their look rather than performance. They have a novel dial concept and at least stand out amongst a lot of the post war ac/dc sets.
Good luck with yours.
I need to get my hippo out and play it some today. Case was cracked on both Hippos I found, but at least they look presentable. I have both an Ivory (working) and a regular brown one (not working).
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
Rogers Majestic R-646
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM
Today I finished inspecting all the parts. The result is not very pleasing. The first positive news: 1) The power tr...Vlad95 — 11:40 PM
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM
There are currently 1046 online users. [Complete List]
» 1 Member(s) | 1045 Guest(s)
