38-17F
Does that thing have any photofinish on it??
Tnx
38-18??? Do you mean perhaps the 38-17 you recently purchased?
If so, then yes, I seem to recall that the front panel of the set does indeed have photofinish; the rest of the set does not, I think.
Yup that's what I meant. Your a mind reader! Tnx I thought I'd ask before I started with the stripper.
I updated the title of this thread to avoid confusion. Icon_smile
I suggest you check and see if the front panel is held in with screws; if so, it might come out easily if you remove the screws. If it does, then you could feel free to use your favorite stripping chemical(s) on the body of the cabinet while you store the front panel away safely somewhere else.
Shadow Meter Bulb
Model 28L
37-60 revision 6
Shadow Meter Bulb
Hickok AC51 tube tester
Model 28L
Hello, I'm restoring a Philco 28L and the output transformer is open. Part number of the transformer is 32-7020. Can...HORSTE — 10:32 AM
Philco 42-1008 conversion kit
I read about a kit to convert the variable speed changer in the Philco 42-1008 into a single speed unit.  That would rem...alangard — 09:30 PM
Tim Well...a chassis is metal. Magnetic or not, it does not matter. A transformer has some hum to it. It is natural. Th...morzh — 08:40 PM
I thought the 83 tube was bad because it looked white but it tests strong. Blue gassy though. I checked the fuse, it was...martinj — 08:37 PM
Shadow Meter Bulb
Ross I am not sure what current limiting effect the incandescent provides. They are two different parts of the sch...morzh — 08:31 PM
There are currently 6152 online users. [Complete List]
» 1 Member(s) | 6151 Guest(s)
