640B cabinet finish
Hello, I am new to this forum, although I have been collecting Philco radios for several years. I'm sure this has been covered before at sometime , but If someone can help, great. I have a 640B tombstone model that is in need of cabinet restoration. My first question is..... Is it brown paint that covers the top and sides or something else? Also, is the front a stain or something else. The front seems to be two different shades according to pictures of other similar radios I've looked at. Any recommendations would be appreciated. Also, do you recommend a paint stripper solution on the wood prior to refinishing? Thanks. Icon_confused:
Hello and welcome!
The front panel of your 640B should be finished with Medium Walnut toning lacquer; the trim surrounding the front panel, as well as the top and sides, should be done in Extra Dark Walnut or Van Dyke Brown toning lacquer. You want a very dark brown finish on the top, sides, and trim surrounding the front panel in order for the cabinet to look like its original color scheme. And do not use paint, that is not authentic. Use the recommended toners.
Good luck with your project!
bob  Nice work on battery . If you don't. Have terminals i have a few spares  Samsam — 02:12 AM
hello mr Fixr, for sure !! I have some radios that I need to make some batteries for too. Sincerely richardradiorich — 12:33 AM
Dittos, sweet b on the battery. Love the "9 Lives" logo, remembered from my childhood. Other neat ones are t...MrFixr55 — 11:24 PM
Hi Morzh, Dunno if the AC EMI caps are an issue. I never liked the concept but never had an issue with these causin...MrFixr55 — 11:21 PM
And no hum without the 7AF7? Not common but I am thinking heater - cathode short. This would introduce hum in this sta...MrFixr55 — 11:14 PM
schematics
Those filter caps in the cardboard tube are easy to restuff, especially the kind with the rolled over end. You don't hav...Arran — 09:56 PM
If you have 5 wires, do this: The wires that go to thick-wire wound winding are the filament. If you do not know wha...morzh — 09:03 PM
I recently acquired a Philco Model 16 Code 126. I removed the power transformer to place heat shrink on some very bad...bobclausen — 08:23 PM
Hello Bob, That battery looks great nice job ! Sincerely Richardradiorich — 08:20 PM
Yes, I plan to put a Velcro closer on the top.klondike98 — 07:28 PM
