40-150 cabinet questions
Hey all,
So, after having rebuilt the chassis, it's the cabinets turn! the cabinet overall is in pretty good condition, no loose veneer or major chips or dings. The finish was so/so but the original decals were in poor shape, so I decided to redo the finish. My questions here are 1- What would be the closest match colorwise? I am using Mohawk Ultra Classic toned laquer. 2. Does anyone have a recommendation for what color/type of paint to use for the dial escutcheon? thanks!
Kevin
The escutcheon color that was recommended to me (and I found quite successful) was Plasti-Kote Odds 'n' Ends fast-dry enamel, #139S, brass. I've only found it the one time and don't recall where (I think it may have actually turned up at my small-town hardware store), but the cap now has 'Philco Gold' written across the top.
Plasti-Kote doesn't seem to be offering the Odds-n-Ends brand but they do have a fast enamel spray with the same designation 139-S "brass" that you might try.
http://www.plasti-kote.co.uk/Product/pco...ode---6751 (Icon_redface after posting this note I tried to find who sells it and I think it may only be in the UK: http://www.ffx.co.uk/tools/product/00719...0ml%20139S , the US catalog doesn't seem to include the product http://www.plastikote.com/pdf/catalog_09_29_10.pdf )
I don't know what you are referring to when you say "tube cathode ground". Ground is a connection to the chass...RodB — 05:56 PM
Good points, Arran. I haven't encountered this problem with any other radio (all earlier vintages), so am learning here....EdHolland — 05:32 PM
Ed; One thing that I will say about these is that Brand Z was considerate enough to make these mica caps easily acces...Arran — 02:34 PM
Do you know what run # your chassis is? It took me a while to find what you were basing updates/modification on as I did...Radioroslyn — 07:34 AM
COLLEAGUES, Thank you all for such good and important suggestions as how to find good replacement parts. I will go fo...palonso — 07:05 AM
Here's what the inside of AM IFT2 looked like, and the other pic shows the discs I made to take place of the mica and ke...EdHolland — 07:40 PM
IF2 will need replacement caps. The arcing was severe enough that the mica is pitted and holed where the HT flashed over...EdHolland — 04:04 PM
My Philco 37-116 Restore
Measuring from center tap like the tube voltages show. Cap 127 is isolated from ground. Cap 127 shown in upper left of p...dconant — 08:05 AM
Are you measuring relative to the centertap or the GND?morzh — 11:57 PM
Still not clear on the wiring interface between the 6A7 and oscillator. After refering to the available schematics and s...Tubester — 07:18 PM
There are currently 788 online users. [Complete List]
» 1 Member(s) | 787 Guest(s)
