Philco T-9
Hi, I was wondering if any of you have had any experience with the Philco T-9 Shortwave radio. I did a a Google search and not much came up. How do (did) they compare to the Zenith Transoceanic series shortwaves? Are there any mechanical woes that I should be aware of before purchasing one? Any what is a reasonable price on one of these in good condition? Thanks. Rich
Nothing much out of the ordinary, in terms of trouble--they need their lytics replaced, just like any transistor radio of the same period.
They're much larger than the 1000 series, and they perform at the same level. Pretty good tone, if I remember correctly.
Bill
Good radio. Check for excessive corrosion in the battery compartment, good antenna and handle and condition of leather covered case.
Some claim the Zenith performs better. There's probably not much difference if both are properly aligned.
The book stowed in the lid adds value. Figure on $50-$125, depending on condition. Recent prices may be higher.
Value of capacitor
If this helps you sort it out just remember 10,000 mmfd or pf = .01 mfd. So 5,000mmfd = .005 mfd.Radioroslyn — 04:23 PM
Value of capacitor
OP here- the parts list calls for an .005 1000 volt mica. It currently has an .005 1000 volt electrolytic that is at lea...bridkarl — 02:09 PM
Value of capacitor
Maybe it's one of those paper caps that is wrapped in a mica-lookiing case.RodB — 01:51 PM
Value of capacitor
I also was wondering what the post about using polarized caps had to do with the subject? The cap is 5nF, does not exis...morzh — 10:22 AM
Value of capacitor
The OP stated that there is an electrolytic in the circuit in place of the coupling cap and wondered what effect it has....RodB — 09:53 AM
Value of capacitor
According to AI... ...assuming the electrolytic that's in it now is polarized... What does your response have to ...DaleHCook — 08:17 AM
Most loop antenna setups are either one continuous loop with two connections or 2 loops with 4 connections. The latter c...RodB — 02:16 PM
Value of capacitor
Not trying to answer for the OP, just commenting on the thread. According to AI... ...assuming the electrolytic that'...HowardWoodard — 02:09 PM
Hello Keith! I've updated your thread with the proper model number. Take care, - GaryGarySP — 01:10 PM
Value of capacitor
Why are you having to replace it? Does it measure out of tolerance? Is it mechanically damaged?DaleHCook — 07:50 AM
There are currently 2868 online users. [Complete List]
» 2 Member(s) | 2866 Guest(s)
