41-295 I.F. harmonics across dial
That would be no problem, since there isn't anything either side of 1500. Thanks exray! I have to get a project off my bench, then I will try making a toroid coil and trimmer. How many turns of wire should I use on the toroid?
Use a -61 ferrite core. That's the most important. Can be any size. FT50-61 would be the minimum size (0.500 inches) , FT82-61 is a good compromise (0.82 inches).
Since we're only tuning one freq at the high end of the band use about 40-50 turns (not terribly critical) of small wire like 28 or 30 gauge. Use a 100pf trimmer cap for tuning.
Sounds good! There's a surplus store nearby that has those ferrite cores in bulk. And cheap!
Thanks again for all your help and advice!
Mike
12' Philco
12' Philco
Hickok AC51 tube tester
Arran If the wire inside cans is the gauges you mentioned, the sole reason for that would be mechanical, to stiffen t...morzh — 12:56 PM
12' Philco
Rod, Yes, I know, but the Giant Philco is not around anymore either, so I go by whoever was alive fairly recently. H...morzh — 12:54 PM
Note that no power cord, power switch, or power transformer switch are shown. That (along with my experience with full s...DaleHCook — 07:09 AM
A pair of wire strippers can give you an idea of what the existing gauge of the wire leads are in the IF can, I think it...Arran — 06:07 AM
My last cabinet for this year
