Don't want to damage the coils...
Since I never worked on a radio that doesn't use the standard variable capacitor for tuning, (this Coronado set I'm working on uses the shafts that move in and out of coil sleeves for tuning), I have a question: Would it hurt anything to spray some DeOxIt onto the shafts and work them in and out of the coil sleeves, or what would you recommend to clean them with? I believe that is where the problem lies with this set in preventing it from receiving stations. Either there is dirt in the coils or one of the tiny coil strand wires is touching something and shorting a coil out. Thanks!
Hi Greg
Some pics would be very helpful. Would not use deoxit. I would try to clean it with a vacuum and a soft brush.
Hickok AC51 tube tester
Note that no power cord, power switch, or power transformer switch are shown. That (along with my experience with full s...DaleHCook — 07:09 AM
A pair of wire strippers can give you an idea of what the existing gauge of the wire leads are in the IF can, I think it...Arran — 06:07 AM
My last cabinet for this year
Philco Predicta Siesta picture over time getting dimmer
I found that the wire insulation was burnt.  The fly back needs corona dope! Why would someone put that there?Platinumblonde36 — 01:09 AM
This is what it looked like beforePlatinumblonde36 — 01:01 AM
Platinumblonde36 — 12:58 AM
Platinumblonde36 — 12:57 AM
I'm finding some strange things in my set and for the most part it's also original, so I need to start going over everyt...Platinumblonde36 — 12:55 AM
12' Philco
There are currently 3474 online users. [Complete List]
» 1 Member(s) | 3473 Guest(s)
