Philco 630 or version?
I am working on what I thought was a model 630 Philco. The label in the cabinet says '630'. There are no labels remaining on the chassis to identify it. I noticed that the service literature shows a wafer board where several capacitors and resistors are mounted, but my chassis does not have this board. It does have two bakelite blocks that are not shown on the 630 chassis layout as well. The 635 chassis looks more like it, but my chassis has a connector plug for the speaker where as the 635 chassis shows hard wiring for the speaker and no plug.
I believe this is the original chassis to the cabinet, and not a swap. Could a 635 chassis have been installed in a cabinet marked 630 at the factory? Could this really be a 635 chassis even though it has a speaker plug?
Any thoughts on this would be appreciated.
Frank.
Hi Frank
The 635 schematic does not have the X marks in the speaker wires, but the 635 chassis has the speaker socket and plug just the same.
Yes, your 635 chassis could very well have been installed in a cabinet marked 630. Especially the 630/635B tombstone, the cabinets of which are identical in appearance. This could have been done early in 635 production.
One thing to check on your chassis - does it have a shadow mask between the dial scale and the stationary translucent part with the three band indicators punched in it? If so it is definitely a 635 or late version 630.
Hi Ron,
Yes, my chassis does have that mask. Knowing what you have just said, I can pull out the correct service info and move forward with this chassis. Thanks for taking the time to help me clear up this confusion!
Frank.
Value of capacitor
If this helps you sort it out just remember 10,000 mmfd or pf = .01 mfd. So 5,000mmfd = .005 mfd.Radioroslyn — 04:23 PM
Value of capacitor
OP here- the parts list calls for an .005 1000 volt mica. It currently has an .005 1000 volt electrolytic that is at lea...bridkarl — 02:09 PM
Value of capacitor
Maybe it's one of those paper caps that is wrapped in a mica-lookiing case.RodB — 01:51 PM
Value of capacitor
I also was wondering what the post about using polarized caps had to do with the subject? The cap is 5nF, does not exis...morzh — 10:22 AM
Value of capacitor
The OP stated that there is an electrolytic in the circuit in place of the coupling cap and wondered what effect it has....RodB — 09:53 AM
Value of capacitor
According to AI... ...assuming the electrolytic that's in it now is polarized... What does your response have to ...DaleHCook — 08:17 AM
Most loop antenna setups are either one continuous loop with two connections or 2 loops with 4 connections. The latter c...RodB — 02:16 PM
Value of capacitor
Not trying to answer for the OP, just commenting on the thread. According to AI... ...assuming the electrolytic that'...HowardWoodard — 02:09 PM
Hello Keith! I've updated your thread with the proper model number. Take care, - GaryGarySP — 01:10 PM
Value of capacitor
Why are you having to replace it? Does it measure out of tolerance? Is it mechanically damaged?DaleHCook — 07:50 AM
There are currently 2038 online users. [Complete List]
» 2 Member(s) | 2036 Guest(s)
