Philco Model 131?
Is this model Canadian? Here is the info I have.
PHILCO MODEL 131, 4 TUBES, AM BAND, BATTERY OPERATED. I can not find any info on it.
thanks
Chris
No Canadian model by that number that I'm aware of.
That's a Model 46-131, I believe you're looking for?
4 tubes: 1LA6, 1LN5, 1LH4, 1A5.
Or is could be a 42-131, also four tubes: 1LA6, 1LN5, 1LH4, 1LA4.
Chuck here is a picture of it. I could not find pictures of it in Ron's book.
http://cgi.ebay.com/270184185168
Any help would be appreciated.
Chris
Yep, that's the Model 42-131.
A picture is not in Ron's original book.
Chuck,
Thanks for the info. Was this model rare?
Chris
Only 10,550 were made, so it's not a commonly found model and fairly rare. Originally introduced in the Jan-Mar 1942 season.
Thanks Chuck for the info. How hard would it be to recone the speaker or find a replacement?
Chris
Hi Chris
Did you buy it? Someone did...quite a bargain.
Being a battery set, the speaker is likely PM so replacement would be easy. Only problems would be matching the voice coil and mounting holes.
Ron,
No I missed out on it. I went to check on it again and someone bought it Icon_sad
Chris
Well, at that price, I thought about picking it up...but I do not need it. Too bad you missed out. Honestly, though, I am surprised it lasted as long as it did before being snapped up.
Same here I do not need it either. Picked up a Philco AM/FM for $20 total. That will be it for awhile. I have enough projects for the winter now unless something special comes along Icon_wink
Chris
Hickok AC51 tube tester
Note that no power cord, power switch, or power transformer switch are shown. That (along with my experience with full s...DaleHCook — 07:09 AM
A pair of wire strippers can give you an idea of what the existing gauge of the wire leads are in the IF can, I think it...Arran — 06:07 AM
My last cabinet for this year
Philco Predicta Siesta picture over time getting dimmer
I found that the wire insulation was burnt.  The fly back needs corona dope! Why would someone put that there?Platinumblonde36 — 01:09 AM
This is what it looked like beforePlatinumblonde36 — 01:01 AM
Platinumblonde36 — 12:58 AM
Platinumblonde36 — 12:57 AM
I'm finding some strange things in my set and for the most part it's also original, so I need to start going over everyt...Platinumblonde36 — 12:55 AM
12' Philco
